Discuss Ultimate Box Set - 30 Diamond Tile Drills and cores HUGE selection of sizes. 365Drill in the Plumbing Jobs | The Job-board area at PlumbersForums.net
http://*********.com/boxset/ultimate_logo660.jpg The most popular box set we have ever produced. A big hit with installers
http://*********.com/boxset/ULT1.jpg
. 30 Diamond cores in a large heavy duty case complete with all tools.
Keep all your diamond cores together. Easy to spot colour.
Its not hard to work out why this set is a firm favourite with installers. Containing a huge number of diamond cores plus all the equipment required to use them efficiently. If you are looking for something substantial and you dont want to break the bank then buy direct from the factory at £199 instead of £299 retail.
What is it ?
What is it used for ?
5 x 6mm
For Red Rawl plugs and small fixings...... http://*********.com/jpgs/redplug.jpg
6 x 8mm
For Brown Rawl plugs for heavy duty fixings..... http://*********.com/jpgs/redplug2.jpg
1 x10mm
M6 bolts with rawl plugs and microbore gas pipe.
1 x 12mm
Small LED lights .
1 x 14mm
M8 bolts with larger rawl plugs..
1 x 16mm
Snug fit for 15mm pipes.
1 x 18mm
Oversized fit for 15mm pipes (Generous fit)
1 x 20mm
Electrical cables.
1 x 22mm
Copper pipes exact fit
1 x 25mm
Tap holes small and 22mm copper pipes loose fit.
1 x 28mm
Body Jets and smaller bore tap holes.
1 x 30mm
Shower heads / shower rose.
1 x 32mm
LED spotlights and lighting
1 x 35mm
Monoblock mixer taps
1 x 38mm
Oversized for 32mm waste pipe
1 x 40mm
Oversided for
1 x 45mm
40mm (ID) waste pipe for a bath or shower - Push Button flush
1 x 55mm
Push Button Toilet flush.
1 x 60mm
Smaller shower valves. Access holes.
1 x 65mm
Shower valves, Push button flush (large) Waste trap for showers
1 x 115mm
Soil stack. Extract fans.
12 x guide plates
Anti-slip plates to lock diamond cores to the tile surface.
1 x guide clamp for 115mm
Stainless Steel anti-slip clamp to guide the 115mm size drill.
1 x J-hook
To remove (eject) the tile from inside the cores perfect on small sizes
2 x sponges
To cool the diamond cores consistently and collect dust
1 x heavy duty case
Bright yellow and easy to spot. Extremely durable tough shell case
Wow !
The most comprehensive set we have ever sold !
http://*********.com/boxset/ultimate_and_clamp.jpg INCLUDES FREE CLAMP FOR THE 115MM DRILL !!
http://*********.com/boxset/ULT3.jpg
[SIZE=+2]THAT WORKS OUR AT A MIND BLOWING £6.69 PER DRILL BIT[/SIZE] And you get the rugged box, the anti-slip guide plate, the anti-slip large size steel clamp, the cleaning hook !
At that price its a no brainer!! Yes I want one....
Re: Ultimate Box Set - 30 Diamond Tile Drills and cores HUGE selection of sizes. 365D
http://*********.com/boxset/ULT4.jpg
This 3KG box really is the ultimate solution with 30 diamond cores in the most popular sizes and also now with and ever wider choice of sizes. Give yourself the best set on the market and grab it while you can at this price. Once we hit retail with it the price will go back to £299 which is still £250+VAT. Retailers are already asking us when we can supply so we wont hold onto this price forever. Included with the kit is our latest innovation the stainless steel push clamp for the 115mm.
http://*********.com/boxset/ultimate_side.jpg THIS LARGE BOX WEIGHS 3KG (ABOUT THE SAME AS THREE BAGS OF SUGAR)
http://*********.com/boxset/ULT8.jpg
Every single diamond core drill plus some more is included in this set. As a company we are very used to providing small kits and packs ideal for installers who just wanted to tackle a few pipe sizes. But this kit gives you the freedom to access any size drill core and not have to wait. Whatever the job throws at you then you can be sure you have the perfect diamond core inside the case. Never have to wait about on jobs for stuff to arrive.
We put a huge amount of stock into the case so that you never have to be worried or caught out. The bright yellow case is in the colours of construction so that you cant lose it. And it looks cool as well. Did you know we make everything IN ENGLAND. And we have selected the best foam for this set. Not many people get excited about foam! But we do... And we know that every part of this set is superior. Obviously you can tell just by looking at the picture but you can be sure UK craftsmen have spent time and love creating this selection box.
http://*********.com/boxset/ULT13.jpg
Having a box is so handy because everything has its place. If a bit is missing then its obvious. Also its easy to grab and carry. And when its time to start drilling you want your equipment to be organised and to hand. The diamond cores are of exeptional quality and standards. Each has been tested by an independant UK company and approve stamped. We used a third party testing company so that retailers as well as installers can be sure of the results.
The steel clamp (non rust!) is perfect for the 115mm but we also punched out a couple of extras for you. There is a 6mm and an 8mm plus some other sizes so you can guide the diamond cores down with accurancy and create a sure start to the tile. INCLUDED FREE IN THIS SET !!!
http://*********.com/boxset/ULT11.jpg
Laid out and ready for work. This system is going to look after you for many many top end porcelain tile jobs. Just seeing the equipment you bring to the job gives your clients peace of mind that you have the right tools. That you are a credit to your profession, that you are a professional who invests in his time, his skills and his tools. Quality equipment made in England.
[SIZE=+2] http://*********.com/boxset/365TOOLS.jpg[/SIZE]
http://*********.com/boxset/clamp2.jpg 1) Anti-Slip Guide Plates : 2) Water Cooling Sponge : 3) Cleaning hook [ YOU DO NOT GET THE BATTERY DRILL! ]
http://*********.com/jpgs/guideplate.jpg
To start the hole push the anti-slip guide plate on the wall. Dip the tip of the drill into some water and that will be enough for you to get the hole started. Give it about 10 seconds of drilling until a pit forms. Now remove the anti-slip guide plate and put the soaking wet sponge under the core bit.
http://*********.com/boxset/ESS2.jpg
To cool any of the drills use the handy sponge provided. Simply submerge the sponge in water (do not wring out) then push it against the rotating core bit. If you are on a wall and vertical then put the sponge underneath to catch all the debris. Easy way to do the job. If you are on the flat then simply drop a puddle of water onto the tile by squeezing the sponge.
http://*********.com/boxset/ESS4.jpg
Finally - Insert the J-Hook (Its like a big toothpick) into the barrel of the 6mm or 8mm to eject any stubborn tile dirt or grit caught in the barrel - Easy!
They are popular - We are selling a lot of them (Well they are a great launch price) For example if you are VAT registered its only £165 quid [Note prices WILL be going up soon]
Maybe I will get Steph in the warehouse to put a message card in the box asking for product review. Its a new product so as soon as anyone does a review we will post it here.
Promising Start: So far we have had not a single complaint or return.
Just to advise I will be working on a video to showcase the 115mm drill bit and how it helps with the install of the Soil stack (at 4 inches)
I have my soil stack pipe. I have my collar. And I have a tile. All I need to do is set aside some time to do the filming. Hope to get it done early September 2014.
At the moment in 2014 the boxsets are ONLY AVAILABLE online direct from the factory.
We are looking at retail and have spoken to the buyer at Williams Plumbers Merchants as well as Tile Depot with a view to listing these. We are also talking to some other retailers with a view to stocking these in 2015.
I clicked on the above link, hoping Laura (girl in picture) will have her kit off and show me how to drill tiles with the said drill bits? Instead, she had all her clothes on and showed me nothing with the drill in action? Damn, I'm dissapointed
After seeing that Sera perform the drilling motion in the nude, I have placed my order. Just a bit worried though?
- They never asked me for the 3 didgit security number on back of my card?
- They made me fill a form about: 1) How did I hear about them? 2)Any comments? I made them aware that Mr 365 Drills refused to give us UKPF members any discounts? He made us pay same as any other member of the public???? I'm not impressed
errrmmm, let him fight his corner kay-jay. Don't do it for him In all honesty, I'm sure Dan wouldn't have had him here as a sponsor if his products were not of high standards.
I'll check my box when it arrives. Hope there'll be some sweets and biscuits in there.
Reply to Ultimate Box Set - 30 Diamond Tile Drills and cores HUGE selection of sizes. 365Drill in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi all
i need some help and advice
i am tiling around 2 shower pipe fittings. as the measurements were intricate i was practicing on off cuts and trying to create a template. I've noticed when i drill holes into the tiles sometimes they would crack. i don't use any pressure or drill too fast...
Hello,
I would very much appreciate some help/feedback on what I am proposing for my very small ensuite bathroom. While refurbishing it I’m proposing to add a shower. It’s just 1.2m x 1.6m. I have seen similar posts to this on the forum but not quite my situation.
I am proposing to run one...
Brand new for April 2016. Launch of boxsets for drilling holes into very hard porcelain tiles.
Two sets have been revamped. The third is completely new.
This boxset is based on our best selling bathroom fitters kit the "All in one solution" A slimline 600g set...
A number of issues have been raised from a boiler replacement.
Boiler not operating and with no pressure.
Tile damage
Sprawling pipe layout in kitchen
(Retrospective view of alternate option when it was found that promise of removing pipes from airing cupboard could not be fulfilled).
Battery...
Here they are!
Totally refreshed for this year. We have given a makeover to all of the BOXSET range. All options are now presented in smart easy use cases.
Do you need to drill holes into very hard porcelain tiles? ********* are the tile drilling specialists
THE ESSENTIAL This box set...
