Discuss Ufch off thermal store, flow temperatures too high??! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
TipTop
Hi guys, any advice for my situation
Ov thermal store with ufch tappings but ufch manifold v close to store,
Problem is store temp at 72/73'c
Manifold has phial type trv and is shutting down v quickly due to flow temperatures
Clearly don't want 72 going through ufch (45ish ideally)
Got a 2port and 15/60 pulling from store
Secondary circ pump on manifold
Any ideas?
Cheers
The TRV is doing it's job.
It should only open and inject hot water from the store when the circulating temperature around the floor drops below set point (45 for yours)
What's the temperature on the pipework to the floor?
Hi nostrum what can I blend with??! It's obviously ch water I've no source of cooler water to blend it down with apart from return
Reply to Ufch off thermal store, flow temperatures too high??! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
