Discuss Trianco TRO 20/25 - New but noisy EOGB pump motor. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
TransitTrucker
I have an old but perfectly working Trianco Oil Fired Boiler. It works perfectly well but it wakes me up in the mornings when it comes on. It isn't the burner jet noise but a bearing noise from the electric pump motor.:builder:
This is a new motor (6 months) and made the noise from new. It is an EOGB part with a prt number of M02-1-90-09.
I have an engineer's stethoscope so I wandered all over the burner to identify the source of the noise. Now, based on the noise gradient it comes from the bearing in the motor's end cap. That is by far the noisiest spot. As you move the stethoscope away from that area the noise decreases.
It seems to be at a frequency that manages to resonate pipes and vibrate upstairs just about where my bed is. I could move the bed but the room is a bit limited in space, should we say.
Now, I don't know whether this make of motor is noisy or whether I have a duff part. I wonder if anyone can chip in with advice or a suggestion (not too rude, I hope) and help me get a full night's sleep.:wink_smile:
Well it's not working perfectly if it's running how you describe.
Get a competent engineer who can resolve your issue and check the combustion with the necessary test gear.
Doesn`t Meady live that area? Or is it somebody else?
It was this area's most competent boiler engineer who fitted it. He has been back to check it as well. This boiler was service by his dad before the son took over the work. The burner is running perfectly well. It is just that the damned pump motor is noisy.
Reply to Trianco TRO 20/25 - New but noisy EOGB pump motor. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open vented system to sealed / pressurized system, new pump ( UPS3 Grundfos ) all new plastic pipework ( extending ) the 22mm feed and return pipes so no...
1K
Hello ! I have recently moved into a new house – or rather a 1960s built house. The central heating system looks to be around 10-12 years old Its conventional mains gas boiler central heating system (not a combi) the boiler is an “Ideal logic 18” – with hot water tank in an upstairs airing...
4K
hi guys, I removed a burner from the trianco tro it had 2 screws below the burner to keep it fitted. It had a danfoss pump on the right hand side face on and the control box on the left face, the blast tube above is a case that's opens up and the fan is in side. The fan adjustment is by a flat...
2K
We recently moved to a rented property. Last Spring it was converted from oil to gas central heating. The property is a 1960'S chalet bungalow. The current boiler is made by Ideal and was new last Spring. The heating works and heats the house very well, but the noise is unbearable. The bedroom...
14K
  • Locked
Hi I've fitter new motor to Inter 2011C burner which drives Danfoss BFP 11L3 oil pump. motor bearings are good fan rotates freely and without wobble. There's a vibration noise from the pump coupling area which I just can't seem to solve. If I slacken the pump mounts and move it slightly noise...
2K
