Discuss Tool to siphon the last bit of water out of cistern in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
NGduffin
Hi, as the title says I'm looking for a tool, something like a hand pump, just to get the last bit of water out a cistern. I remember a plumber I worked with once had
a high pressure plunger like a big syringe so when submerged and the handle pulled it sucked water and held it. I wondered if any of the big diy stores sold them as I could do with one tomorrow.
Thanks all
I've used these, can be used for other cleaning too!
Microfibre Cloth Pack of 50 | NoLinkingToThis
May be available elsewhere cheaper.
I have one of these, under a fiver from motor accessary shop.
This is what the O.p is thinking of;
Sink & Bath Unblocker | NoLinkingToThis
Bucket and a bit of hose if I can't be bothered getting the wet vac out.
OR
lots of towels and pull out the inlet valve, I don't do this, unless the floor is tiled:devil:
Manometer tube into pan and a good old suck, or a decent tilers sponge. Had one of those hand pump siphons, lasted 2 mins.
You could get one of those tools they use for testing car battery's the one they stick in the holes and squeeze the rubber bulb on top and sucks the liquid out no idea what it's called
Which cistern are we talking about here?
two bloody pages on how to get the last drops out of a cistern ffs as anyone heard the word 'ingenuity' ? or the term ' use ya noggin '
manometer tube you could fill a van with gadgets best to use whats available one end in cisten quick suck and drop into pan
Sponge is the easiest way. Flush the loo, and get ris of what you can, and use a sponge for the rest. Or the wet vac if you really can't spill a drop.
I tried the manometer tube method, and it takes ages.
Only time I syphon is on high level toilets, a sponge is a lot quicker
dont forget gloves for the blue loos!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Just loosen the float operated valve and hold a bucket under it.
flush toilet, disconnect all connections, lift toilet out and pour down toilet (if in rush and cant be bothered with wet vac)
dont take connection off as doesnt go in bucket, it leaks everywhere
dont use sponge or any other contraption as takes too long and never find it in van and it will break when rattling round the van!
Reply to Tool to siphon the last bit of water out of cistern in the Plumbing Jobs | The Job-board area at PlumbersForums.net
