Discuss Three way valve in Morco Boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Even if your not touching the gas side of it? Cause you don't have to go into the combustion chamber. What about if you are classed as "competent"?According to the rules , you must be GS to remove a boiler case
It's the Morco combi Boilers and its more just for a work perspective as I have been asked to do it before but I wasn't sure if I could with out been gas safe, yea it's LPG not domestic and it's the diaphragm that goes inside the three way valve. The outer case is just purely decorative to cover all the bits inside, the combustion chamber is sealed in a separate bit within the boiler? Hope that this makes sense and thank you for all the replies.
then your fine
He has to go into the combustion chamber to disconnect pipe from water section in order to remove complete water section, not advisable just to replace diaphragm all seals need to be replaced its a pig of a job to do
I have watched my boss replace the just the diaphragm a few times, it usually seems to solve the problem and maybe we are on about different boilers but on the ones I have seen my boss do and also done under the supervision of my boss, you don't have to touch any of the gas pipes just the water side of it. Thank you for the reply, it seems like such a grey area I just don't want to do something I aren't supposed to.He has to go into the combustion chamber to disconnect pipe from water section in order to remove complete water section, not advisable just to replace diaphragm all seals need to be replaced its a pig of a job to do
Morco now recommend that the push rod seals be replaced at the same time but this is on the FEB range not sure what Morco boiler OP is on about.I've replaced just the diaphragm a few times all has been ok
Reply to Three way valve in Morco Boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
