  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Discuss Thermostatic triple diverter shower valve with body jets and shower rail set in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. fletcher7751
    fletcher7751 New Member
    Hi all, seasons greeting
    I have been volunteered to install the above, outside of my usual kitchens and bathrooms so seeking some advice
    There are three outlets, the rain head, hand held and three body jets to two facing walls.
    I understand that l can have two outlets on at one time, what is the usual way to plumb these in, there would have to be two of the above on at the same time - which two?
    Also there is no pipework or fittings to connect to any of the outlets, should this be in 22mm or 15mm, it is supplied by a new Ideal Logik.
    Any advice gratefully received, and a lesson on what you agree to whilst under the influence!!
  2. ShaunCorbs
    ShaunCorbs Trusted Plumber GSR Top Contributor!!
    What's your pressures and flow eg is the shower suitable for it
    And normally 15mm into the valve but you can if you want do 22mm as close as easily
  3. fletcher7751
    Hi Shaun, thanks for reply
    As usual, client bough it as it looks good....
    Manuf say min pressure 1.5 bar and we are fine with that, will do a flow test, but they don't mention that in their sparse instructions
    All the connections to the valve body are 22mm incl the outlets
    I'll ask the client what they want, but l suspect wall jets on one outlet, and drencher and hand held on the other. .
    I am concerned that they will need a fire pump to operate them all though! I expect one outlet at a time in use.
    One of the walls with the body jets is an old hard brick wall, so happy days chasing ahead.
    At least one is a stud wall, that's where the valve body will be going!
  4. ShaunCorbs
    If there 22mm pipe up in 22mm but confirm pressures and flow first :)
  5. fletcher7751
    Will do, any idea on required flow rates?
    Ill check with VP....but don't hold out much hope there
  6. ShaunCorbs
    Should say in instructions but aim for anything above 15lpm as anything less will be less than 7.5 lpm with two heads on
  7. fletcher7751
    Cheers Shaun, will check that first
    Also would l need a pressure loop each side, as it's serving six body jets?
  8. jtsplumbing
    jtsplumbing Plumber GSR
    Best of luck with it, another item purchased by customer, sounds like import rubbish, no proper instructions, Hope its WRAS approved ! check B4 you fit it, and if you do explain if it does not work it's down to them to sort it out,
    • Like Like x 1
  9. ShaunCorbs
    Won't harm to connect them all together and to the valve twice
  10. fletcher7751
    Its from Victoria Plum (no B!!)
    Don't know country of origin, wasn't cheap.., but instructions next to carsy paper!
    Will explain believe me, but first the flow test
    May end up fitting three body jets, they want three on opposing walls, but very concerned at supplying them all
    Thanks for all replies
  11. ShaunCorbs
    Will be China
    • Like Like x 1
  12. fletcher7751
    Update - couldn't bring myself to struggle with no instructions, means of sealing and retaining either the body jets (has rear lock nuts!!!) or the valve faceplate other than silicone it the client agreed to return it. Now looking to get some proper kit, any suggestions? I am thinking a two way diverter for rain and 4 jets (not 6), and a separate hair shower on riser rail. That gives a working shower if either needs maintaining, and they will all be separately controlled.
    All suggestions of manufacturers greatly appreciated,
    Budget £400.
  13. ShaunCorbs
    Yea normally bin them (the lock nuts) and use soldered back plates
    Grohe very good shower manufacturer
  14. Plumbstar Tom
    Plumbstar Tom Well-Known Member
  15. fletcher7751
    Thanks very much chaps, will get a trade price on that, retail will cause cardiac arrest for the customer!
    Any suggestions on which decorative valve for the jets, seen Aqualisa at £120, hoping for half that!
    At worst l can access the back of the body jets via a hole in the stud wall until plastered, l can't see how PTFE on the jet to the supply can be watertight, which is what the suppliers are telling me.
    Are these the backplates you suggested - www.screwfix.com/p/swirl-bar-valve-wall-mount-fixing-kit-chrome-plated/8669h
    How is the jet to connector joint made watertight?
    Sorry for all the questions, and very grateful for the advice
    Best wishes
    Fletch
Loading...
Similar Threads - Thermostatic triple diverter Forum Date
Need some help with a Triple thermostatic shower mixer.. Bathrooms, Showers and Wetrooms Sep 21, 2016
Identify correct thermostatic cartridge for dripping shower taps Bathrooms, Showers and Wetrooms Jun 22, 2017
Can this thermostatic mixer tap be flipped? pic included Valves & Taps Jun 22, 2017
Quick question on Thermostatic Cartridge Plumbing Forum Jun 21, 2017
Thread for thermostatic valve handle has worn away totally. Help! Valves & Taps Jun 16, 2017
Thermostatic shower issue- please help! Bathrooms, Showers and Wetrooms Jun 13, 2017
Can anyone help to identify this shower thermostatic cartridge? Plumbing Forum Jun 10, 2017
