  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
  2. WARNING! We do NOT provide advice related to Gas or other fuels to people who are not currently an official registered Heating Engineer. Do NOT ask for advice related to boiler repairs or installs. You need to find a heating engineer instead.
    Either seeking or providing advice on UKPlumbersForums.co.uk may result in your account being suspended or removed. These rules are in place to prevent deaths, which can easily occur from messing with heating systems when you're not qualified to do so.
Discuss Thermal Store in the Oil and Solid Fuel Forum area at UKPlumbersForums.co.uk.
  1. alanfym
    alanfym New Member
    Hi.
    I have a thermal store system, heated by Parkray log burner (LB) with a back boiler, and a Grant Oil fired (OFB) boiler. These have separate pumped circuits apart from the thermal store. Using the Grant OFB as the heat source is no problem.
    The way its set up seems strange - when using the Parkray LB, the LB "hot stat" (stand alone) cuts in ok at hot temp set and starts the associated pump so water circulates thro LB and thermal store. Fine.
    When the coal fired boiler dies the pump continues to run circulating water thro the LB. boiler and thermal store until the water has cooled enough, and the LB stat switches off. This takes a long time and also lowers residual heat in the thermal store which is wasteful/inconvenient.
    If the programmer is on a "normal auto" programme, and the thermal store water is still hot/above LB stat temp setting (60deg.C), but below thermal store stat setting (90degC), the oil fired burner cuts in as it should, however the coal fired boiler pump then continues to run. I need a way of switching this pump off when no heat from the LB (could put manual off/on switch but..) suggestions on redesign welcomed
  2. PhoenixServices
    PhoenixServices Plumber GSR
    I would suggest calling out a hetas engineer who specialises in these sorts of systems to look at the current setup to see what can be done.
  3. alanfym
    alanfym New Member
    I thought I had one - the one who installed this. Anyone you care to recommend around Tunbridge Wells
Loading...
Similar Threads - Thermal Store Forum Date
Thermal store question Central Heating Forum Mar 10, 2017
Advice needed for thermal store to radiator supply Renewable Energy Feb 15, 2017
Experience with thermal store Central Heating Forum Dec 29, 2016
Immersions on a thermal store Plumbing Forum Dec 23, 2016
Edmonton, London - Thermal Store replacement Looking for a Plumber? Post Jobs Here Dec 1, 2016
thermal store Plumbing Forum Nov 1, 2016
Thermal Store Vs Unvented Vs Pump Plumbing Forum Oct 1, 2016
