Discuss Tap tools in the Plumbing Jobs | The Job-board area at PlumbersForums.net
imagine bending the end of the spanner just where the flats are 90 degrees and there you have it
i use the monument spanner easy and simple not had a problem with it and good in tight spases
Toolstation > Hand Tools > Plumbers Tools > Monument 2 Jaw Adjustable Basin Wrench
About time, see they have a place to clip on the jaw you are no using at the time to stop it getting lost, must of spent a fortune in lost jaws over the years !!:
Although it's a screw and I've found it works loose and ends up lost in the toolbox.I've put some PTFE on the thread to try to stop it coming loose.Might work!
Reply to Tap tools in the Plumbing Jobs | The Job-board area at PlumbersForums.net
