Discuss Tanking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Meady
Re doing my own bathroom at the moment. I was ripping the bath out today and all the tiles / plasterboard back to the stud wall and it looks like a lot of water has got back there.
I was thinking about tanking it before tiling but I've never done this before. The plasterer is coming in next weekend to plaster the lot.
my question is what would you use to tank it and do you plaster then tank then tile? Cheers
If it's plasterboard that was on then you need to use aqua panel or similar not sure wether you skim it or not (I only do pipework) others do tiling etc. Someone will know better
with aqua panel you don't need to plaster just tank. with plastering the weight of tiles and adhesive can't be as much as without plastering
As above, use aquaboard or marine ply. And one or two of these tanking kits as required.
http://www.NoLinkingToThis/p/mapei-...tracking url&gclid=CKL_uLeuus8CFUieGwodInoLHQ
Looks like it's a timber framed house (modern) am I right?
Aqua panels or similar will do, or even moisture resistant plasterboard I would ceramic tile straight onto that substrate and not skim, wet trades in a timber frame house should be minimised.
just make sure the insulation is bone dry, before you cover it and kill any mould spores with a bleach spray... you will need to replace any wet insulation, it looks like the insulation is covered in clear polythene membrane which looks like it has moisture behind it.
Agreed, using it in mine at the moment
It might be sweating also
Rip the plasterboard out and use a cement board or backer board like hardibacker or wedi boards. Tank it with 2 or 3 coats of Aquaseal (1/3rd of the price of mapei)
Don't whatever you do plaster it.
If it is a solid wall cement render it.
good advice as per normal
If you need to render it put some seka waterproofer in your mix.....regards Turnpin:biggrin:
Reply to Tanking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
