Discuss T4TS plumbing scenarios in the Plumbing Jobs | The Job-board area at PlumbersForums.net
LUCIALIA
Is anyone else having any problems with the scenarios, i just wanna chuck it out of the bloody window. If anyone has any walk throughs, it would be appreciated as i can fix the problem no worries but not complete it exactly as the program wants & it driving me nuts!
hi mate i dont know how to do soundness test in senario 3
please help me
akh
hi mate, the scenarios are a pain,,,scenario 1 their are nineteen thing to check basically everything to do with the cold water system, count them as you go along isolators,taps,toilet etc,etc....
scenario 2 hot water check,the immersion heater has been left on and its too high,turn it down to 60 degrees again check everything to do with the hot water,
scenariol 3 not done that yet,got as far as a soundness test and failed so got bored with it.....good luck
hi got this disk of a mate for fun.
check every thing that is wet plumbing, it will tell you if not relevant.
and dont forget to leave the house as you found it water / heat on doors shut etc.
Good day one and all, I am also struggling with the soundness testing!! do you have to check each piece of pipework which is adjoined to the isolation/service valves?! I do know after many times of being told that you must turn the boiler OFF before you play with the gate valve. Will give it another attempt when kids are tucked up in bed!
Regards James
I am also struggling with the soundness test in sanario 3, if anyone has any advice it will be very much appreciated
are you referring to a gas tightness test ?
no the soundness test for hot and cold water systems. (scenario 3 on the Trade 4 trade skills virtual reality cd). Ive read the guide in my book but its not the same in the VR house, you cant just go to your toolbox and grab a tool. the last problem i had to solve was two leaking taps but it wouldnt let me change the tap washers i had to replace the taps with new ones, shurely i should have had both options.
Did anybody finish the senario 2. I have problem with the hot water system check, rest is done, it is 18 points to inspect. Somebody can tell my whom from kitchen&cupboard has to by inspect. help please its getting me mad
I have not heard of these scenarios are they part of an on line plumbing course ? Where do you get the Cd's ?
They seem okay as scenarios to me.
They seem to be picking up on any underlying knowledge required to answer them.
In real life of course it often doesn't work like that.
A Plumber usually has to think on the job, not go home and look in a book.
Its great if you can of course and sometimes you get the opportunity to do so.
Working for small repair companies however, where you don't even know what your next customer will want, it works differently.
If your an employee, your boss will expect you to be able to do what he is paying you for and that means any job in Plumbing.
That means from ships plumbing to oil refinery to tap washers.
You would need a library to cover it all and have the time to read it.
Your head would be so full of information you could probably be so distracted from your often dangerous surroundings you could trip, and hurt yourself.
The key is to do your planning first and then the job, so you don't mix work with learning.
But how do you do that in a small firm when you don't know what sort of job you will be doing in the next half hour let alone day?
Learn as much as you can about how things should work, then you will know why they don't.
And don't be afraid to ask questions or look in kids books for answers.
Have a read of a Physics book, go to one of the junior school websites and learn the basics from the start.
And don't think your too old or sophisticated to do that.
You don't of course have to go down to the sub atomic particle level of matter to understand what your doing, although that helps, but just far enough so that you do understand.
Also what you do sometimes find is that the same principles of Plumbing apply equally to an oil refinery as they do to your house only the pipes are usually bigger.
Wait till you get piece of 24" Spun cast iron to play with. You can get bigger of course, but that is usually the heavy mobs job. :)
You will spend all day trying to work out how to move it, let alone do anything else with it. And no a nice man with a crane isn't always there.
You have to ask "How deep is the hole, its going in?" "Is the hole properly shored up!"
Loads of questions about none Plumbing things that are all part of Plumbing.
Its all a good laugh. And don't forget to relax and have fun at some point. :) :)
scenario 2 the immersion has been left on,the thermostat on the immersion is set to high,turn it down to 60 degrees,check everything to do with hot water,
ps i have the completion code should you need it, hope this helps
hello can you tell me please
step by step how to do the stupid scenario 2, I done all settings but the hot water check is p..in .a ... help
Hey folks if you contact your tutor team you can get a walkthrough guide from them
please help me
akh
Im having the same problem now and its getting bloody annoying.
I can do everything in this scenario apart from the Cold and Hot Water Soundness testing. What am I doing wrong
Ive checked absolutely everything (twice!) and Ive even left it for 15 minutes in case but still No!!
It would be nice to get more details from the results rather than 'you did not complete a soundness check on the hot water/cold water' At least give us a clue what we are missing
Can anyone help before I start using the CD as a lethal weapon by throwing it at something?
Basically, the same as the above. How do i do a full hot water check ?
I've done everything else for scenario 2
can anyone tell me where i can get theses cd's ...nothing like this in ireland and i would love to suss it out for the craic !!!
So would i just incase i have forgotten anything.
Just had a read through some of this............walkthroughs?????????? what is that all about. This plumbing game is far removed from call of duty or what ever other game you get walkthroughs for. Suss it out for yourself.
hi all
im also having probs on the soundness testing if any one susses iit please let me know and i willl also
cheers chris
Read your books and follow it.
Fk me it is hardly rocket science. A wean with a biscuit rse could do that.
any chance of getting one of these CDs, just out of intrest;has anybody got one spare?
the books for these scenarios i.e scenario 3 (that i am stuck on) dont tell you how to perform the task, just regulation and very basic info. Really poor as ive never done this work before, so what it tells you is to cap off vents; then tells you about what water pressure should be. Sod all else really nothing about where to attach pressure gauge or how to go about even starting the job. Soundness test on hot and cold water systems. Please can anyone help?
what does that tell you about what your spending you hard earnt cash on???????????????
is it worth it???????
Finally completed scenario 3. soundness test. thanx 4 the help. Really have to search with the mouse and the graphics movement isn't good so the option wasn't appearing to connect pressure kit. thanx anyway
Hi all im new to this site i've been trying to do scenario 3 managed to change taps do soundness check on the hot/cold and do the full system check but yet i still get you have not completed this scenario its becoming very frustrating out of intrest rockdude as you've completed it any ideas what im missing? I made sure the boiler was turned off before turning the gate valve off
finally got scenario 3 completed!!! i have completion code and access code for the next scenario if any1 wants it :)
look under kitchen sink washer pipes not the valves red and blue pipes put cursor on pipes pressure test here
hi m8 senario 1 a col;d water system check i done every thing on it and still cant how 2 find out how 2 doing it it really got my head messed up
it should only be there to support learning not replace i. my fear is steve that people think this is enough
it's just that the importance that people put on these scenarios. it's not like this in the real world at all. the stopcocks are not all in the same place for instance. even in the same row of houses the plumbing will most probably be different having been worked on over the years.
stop cocks only work for the first 12months after installation. then they are there just to confuse you or to be a divide between bleech and shoe polish in the sink cupboard;)
Reply to T4TS plumbing scenarios in the Plumbing Jobs | The Job-board area at PlumbersForums.net
