Discuss Strainer & Mangnaclean or just Magnaclean in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I saw on YouTube a plumbing company always installs a Magnaclean and a strainer on new boiler installations, is this overkill or a good idea?
Hi Ian
I would say it's overkill, if the system is that bad/dirty that the PLUMBING company thinks it needs a strainer in addition to a magnaclean then maybe the system would benefit from a flush, either manual or power.
I would add that a Spirotech system filter does filter particals down to
  • Very small particles, from 5 μm (= 0.005 mm) and up are separated and removed
And alot of others will perform in a similar way.
I have seen it done especially on gloworm and Valliant boilers combis and system which rely on a pressure sensor they certainly don't like a dirty system , but any reputable installer would throughly clean a system before fitting a new boiler or after installing a new system. Cheers kop
A good magnetic sludge filter should incorporate a fine strainer there are a few on the market - if you cannot find one reply and I will check my records
Hi Rob, I have a magnaclean and my system is clean, I was interested in what plumbers thought about having both over having just a magnetic filter.
Hi Ian, non magnetic strainers are good bearing in mind the amount of 'plastic' pipe fittings and components in heating systems. Any fine debris can block the narrow pathways in modern boiler heat exchangers. A good combined unit is made by Trappex. I was heavily involved in the development of magnetic filters with a number of uk companies from 2000-2010 NOT Trappex tho so this is not a sales pitch !
Reply to Strainer & Mangnaclean or just Magnaclean in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I need some advice connecting my bowl sink to the waste. There was a Insinkerator installed that I have replaced with basket strainer waste (Viva PP0011). I need to connect the waste but I find myself going around in circles in regards to selecting the correct parts. Thanks FrankW
C
Good morning I have a Adey's magnaclean filter fitted onto the flow pipe ,and when i had it serviced the plumber said all that is going into it was clean water and it should be on the return ? can you help.
I have an 18 month old boiler that was installed with a forced hot water heat loop and a HW storage tank. About 4 times a year I need to clean the strainer. It becomes so blocked that the HW loop starts banging and the water temp at the taps goes way up so you can’t hold your hand in it. I...
Seems strange and I may be reading the MI wrong but i dont understand how the return pipe seems to be hotter than the flow. I have a Vailant EcoTec 438 conventional condensing boiler. Here's a photo of the install. You can see the plumber put a Magnaclean on what i thought is the return flow...
1K
Hi I have a system boiler (Worcester Bosch). There is a Magnaclean filter fitted, which I assumed was just on the central heating. Heating was turned on a couple of days ago and the pressure on the boiler has been dropping. Last night I made sure the heating side was turned off, wrapped...
1K
Deleted member 120897
