Discuss sprint v2 analyser charger in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Gary80gas
Ive mislaid my charger for gas analyser sprint v2. Will any 12v charger be safe to charge it?
I've just checked mine and the mains charger is 15v, but the in car one is obviously 12
So I'd say yes on the 12v question, just take longer to fully charge
Or give Anton a call to be sure
Thought it was more to do with the output ie. 0.8A, 3.2A, 5A, ...............
I lost mine and got a 15v universal charger from maplin. Did the job and no problems for 6months. Calibration company said incorrect charger and the office bought proper one.
As above, as far as i'm aware the lower the volts and amps the longer it will take to charge. Too high volts could damage battery. Too high amps doesn't matter as unit will only draw what it can. Too low amps and it takes longer to charge.
Anton will say to use the approved charger...
Reply to sprint v2 analyser charger in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
