Discuss Soil Pipe Slip Coupling in the Plumbing Jobs | The Job-board area at PlumbersForums.net
May I ask the illustrious members of this forum - I need to replace a vertical section of grey 110mm soil pipe serving a bathroom/toilet. I intend to use slip couplers. Is it likely that the slip couplers will creep over a period of time?
Thanks,
G
No you should be fine unless you have excess movement on your stack
If your paranoid about it you could put a clip below the coupling so it's touching so it definitely can't move
Reply to Soil Pipe Slip Coupling in the Plumbing Jobs | The Job-board area at PlumbersForums.net
