Discuss Soil pipe not sealing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Chaps...I have installed a new 110 soil stack which has 2 elbows on the bottom end each has a 50mm push fit socket.
One of the sockets will not seal even though it only has the boiler conden pipe dribbling into it.
Is there any sealer that I can put into the socket to help create a reliable seal?
No sounds like the rubber seal is damaged
You need to take it out, put the rubber back in place(can be tricky sometimes depending on the brand) file the end to a nice chamfered edge and use some lubricant so it goes in smoothly
Reply to Soil pipe not sealing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
