Discuss Siamp dropvalve .......... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
townfanjon
Subscribed
ehup guys , do any of you fine chaps know if the new siamp drop valves are interchangeable with the old ones , i.e. the cradle bit through the cistern base .
Thank you in advance
No idea mate. I was asking myself the same question as I have one of these to change on Monday. I am taking a close coupling kit just in case:confused::confused:
Or sell them a longer job and a fluidmaster and you won't need to replace it again in a couple of years
Yep I use Fluidmaster gear , but dont know if it will fit the Siamp cistern , its a concealed one and just dont have time .
Reply to Siamp dropvalve .......... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I am trying to find an alternative flush valve to fit the cradle of a ideal standard push btn flush. It is all tiled in and changing to a Siamp or fluidmaster is not an option anyone have any ideas Thanks
Hi, I'm looking for a siamp part, it's the white washer under the cap that flips off. I've recently changed the inlet valve and realised the water isn't cutting off because this washer has become hard and brittle so it's not moving. I can't seem to find this part. btw, I don't know what's it's...
Hi there, our flush valve is still raising but refusing to drop back down. Been to all the plumbers merchants but none have anything that will click into the existing cradle. Its going to be far too difficult to remove the cistern and replace the cradle. Any advice pleas on where I might be...
Hi. Could somebody recommend a Muslim shower valve that does not leak please? Or one that has a washer that you can replace if it leaks? Some sort of tap will be fine that you can connect the shower pipe to please, ideally in chrome? Many thanks in advance
