1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
  2. WARNING! We do NOT provide advice related to Gas or other fuels to people who are not currently an official registered Heating Engineer. Do NOT ask for advice related to boiler repairs or installs. You need to find a heating engineer instead.
    Either seeking or providing advice on UKPlumbersForums.co.uk may result in your account being suspended or removed. These rules are in place to prevent deaths, which can easily occur from messing with heating systems when you're not qualified to do so.
Dismiss Notice
Couple of important things to note. 1. We use Cookies, deal with it. Every website does. 2. Nobody but a currently-registered Gas Engineer should be touching gas or gas appliances. Don't mess with gas at all.
Discuss Shut-off valves in new flats in the Gas Safe Register Forum - Public Forum area at UKPlumbersForums.co.uk.
  1. John Cotton
    John Cotton Guest
    Does anyone know if it is now mandatory to have the shut-off inside new build flats, rather then outside ?
    I'm project manager for a builder and the plumbing company have told us this, but we're concerned as the mains come in along bedroom walls in every flat and they will look terrible, even if boxed in. THANKS, JOHN
  2. Plumbstar Tom
    Plumbstar Tom Moderator Plumber
    i think the regs state that isolation is needed to each dwelling
    so can you not just keep the pipe running along the bedroom wall to the kitchen and pop it uner the sink in the kitchen or something?
  3. John Cotton
    John Cotton Guest
    We were told that the shut-off valve had to be located at the point of entry into the property - any thoughts ?
  4. Plumbstar Tom
    id have to dig out my BS6700 as its in there but to be honest it will take me three days to find the right page, hopes one of the others chaps or chapesses on her can advise.
  5. tamz
    tamz Guest
    Here from BS6891
    8.17.1 An additional emergency control valve (AECV) shall be fitted:
    a) to the installation pipe where it enters the building if the meter is sited 6 m or more away from the
    building; or
    b) inside individual flats served by a large single or multiple meter installation located in a remote or
    communal area (see Figure 7).
    Here is the rest of it
    8.17.2 Every AECV shall:
    a) be labelled or marked to show its open and closed position;
    b) be fitted in an accessible position;
    c) be easy to operate;
    d) be fitted with a suitable handle which is securely attached, or other permanent means of operation;
    e) where the lever moves in the vertical plane, move to the “off” position in a downward direction.
    There shall be a permanent notice attached to the valve giving the following information:
    a) the valve is an “emergency control for customers’ use”;
    b) details of the parts of the installation isolated by the valve;
    c) the telephone number of the Gas Emergency Service; and
    d) advice to the customer on actions to be taken if they think they can smell gas.
    8.17.3 A pressure test point shall be installed no more than 300 mm downstream of the AECV.
  6. John Cotton
    John Cotton Guest
    Does this mean the valve should be at the point of entry in the flat, or anywhere ? What does Figure 7 that is mentioned ?
  7. tamz
    tamz Guest
    Fitted at point of entry.
    Figure 7 is just a drawing of remote meters with risers to flats.
    Should have been picked up at design stage. That is what architects get paid for. Allegedly.
  8. John Cotton
    John Cotton Guest
    Just to be sure - as this is going to affect the saleability of 24 flats - the scenario is that the meters are outside, in boxes at the bottom of the building wall - are you saying that this will require valves at point of entry of each flat ? The reason i want to be clear is that the valves, next to the meters outside are not 6m away horizontally, although they may over 6m if you also measure vertically, as its a 3 storey building.
  9. kirkgas
    kirkgas Trusted Plumber GSR
    there are 2 different points to look at, 1 is a remote meter (more than 6m away needs an extra valve) or 2 communal area with all meters feeding individual flats (which you do have 6m rule doesnt apply here but your scenario needs extra valve in each flat) the 6m rule is walking from the meter to the front/back door to the property, not as the crow flies, potentially the bottom flat may be within this distance and wont require an additional valve, (as it is in effect the same as a house with external meter depending on position of meter) but all other flats are 99% likely to need one. its no comfort to know we see 1000's without, but it dont make it right, not really sure whether it is a Project Managers job to be sorting this as the installer should have both a design with it on it, and a working knowledge to advise you the design is wrong, get back to the archietect and advise him your installer says his plan is mince and let him sort it out, oohh what will cost an extra for someone to pay:D
  10. tamz
    tamz Guest
    There were other ways this could have been overcome at the design stage. It is the architects bolz up. It seems as though you already have the services fitted so you will have to work with what you have and work them in.
    If you don't allow them to be fitted, then firstly, the installers have every right not to sign the work off, you will probably get pulled by building control, but if not, it would most certainly be picked up by the first gas reg guy who visits and classed as at risk.
    This may then open a fresh can of worms with the work having to be done retrospectively.
  11. stevetheplumber
    stevetheplumber Plumber GSR
    point of entry can be outide the flat which is where we always try to design them to be
    i realy cant imagine a carefully disguised gas valve will actually stop some one buying a flat
  12. easyt
    easyt Guest
    I know nothing of regs - but aren't the valves normally sited alongside the meter in most homes eithe rindide the house or outside? _ I don't have gas.
Loading...
