Discuss Shower valve connectors leaking - tried everything! in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Jojo
    Jojo New Member
    Hi, I have just installed a thermostatic shower using SpeedfiT fittings and plastic pipe. Both the hot and cold Speedfit brass male connectors leaked after a day or two of using, (leaking from the connection to the shower valve) so researched online - used ptfe tape (wrapped 20 times in the right direction) with Fernox LS-X left overnight to set. Been using the shower for 2 weeks and just when I thought it was safe to start tiling a small leak appears from the cold connector this morning. I don't know what else to do! Could the shower be faulty?
    All advice much appreciated!
  2. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    Any pictures please
  3. ShaunCorbs
    loctite 577 if it's an all brass male and female thread
  4. Jojo
    Jojo New Member
    Both front and back attached
  5. Jojo
    Jojo New Member
    Ok thanks - do I use without ptfe tape?
  6. ShaunCorbs
    Two options
    One
    More ptfe 20-25 rotations/ layers
    Two
    Loctite 577
    • Agree Agree x 1
    • Optimistic Optimistic x 1
  7. ShaunCorbs
    Without and works 100% or the time but the lsx will need to be cleaned off the threads
    • Like Like x 2
Loading...
Similar Threads - Shower valve connectors Forum Date
Looking for a Westminster 1902 bath/shower mixer valve diverter Valves & Taps Feb 3, 2018
Identifying shower valve ... Valves & Taps Jan 22, 2018
