Discuss Shower temp issues in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Neil Kemp
    Neil Kemp New Member
    Hi
    I have a Mira Sport 7.5kw and am experiencing a problem with the temperature running hot and cold.
    I have carried out all of the initial tests and also replaced the flow pressure switch but still no joy.
    Have also tried different shower head and hose but no joy
    Could it be a costly fix?
    The shower is 3 years old so don’t want to spend loads on it as probably cheaper to replace
    Any ideas?
    • Agree Agree x 1
  2. Riley
    Riley Plumber GSR
    Probably scaled up
  3. king of pipes
    I would check the inlet filter if its partially blocked this would cause the problems your experiencing. Cheers kop
  4. Neil Kemp
    Hi
    Thanks for this and checked it out but couldn’t find anything. Spoke with Mira and they said the heater tank might be scaled and that is what would cause the problem. I looked on top of the heater tank and there were signs of scale, so will now replace that and see if it helps.
    Neil
Loading...
Similar Threads - Shower temp issues Forum Date
Shower options?? Bathrooms, Showers and Wetrooms Friday at 8:33 PM
Quadra waterfall bath shower mixer, two screws missing. Plumbing Forum Jul 5, 2018
