Discuss Shower Pump Size in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Best
    Best Trusted Plumber
    Small delivery charge to NI, but at under £10, worth it for the saving in the pump cost
    • Like Like x 2
  2. ShaunCorbs
    Yes sorry forgot you were top of the morning
    • Funny Funny x 2
  3. YorkshireDave
    YorkshireDave Plumber
    My two penneth.
    First, you need to understand how much hot water you have stored (hot water cyl size). Why? Cos using a 1.4 bar pump will mean twice the time showering before hot water runs out.
    Second, It's vital, whichever manu you choose, the whole thing is piped correctly using a minimum of 22mm copper with full bore valves.
    Third. Make sure your cold water storage in the loft is at least twice the capacity of the cylinder and that the cold feed it taken out loeer than the hot.
    Lastly, re sound. If you want the quietest pump DO NOT mount on something soft. Mount on the BIGGEST piece of dense concrete paving slab you can accommodate. Make sure the pipework is supported and also make sure the flexis have a little play in them when finally in position. The dense concrete will dampen the sound.
    HTH
Loading...
Similar Threads - Shower Pump Size Forum Date
advice please: my plumber connected combi boiler to a shower pump Plumbing Forum Sep 14, 2018
recurring airlock in hot water feed to shower pump Bathrooms, Showers and Wetrooms Sep 13, 2018
