Professional Plumber Required Shower Power Booster
Discuss Shower Power Booster in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
AlanWright
The 'Shower Power Booster' is a new shower pump which is now being sold all over the UK (and Southern Ireland).
I am looking for professional plumbers to feature on my web site as a resource for customers wishing to employ a plumber who has knowledge of fitting this new pump for:-
Gravity systems
Electric Showers
Combi Boilers
And
Boosting Central Heating Systems
Please contact me through the web site.
Reply to Shower Power Booster in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have just had a boiler, hot water tank and power shower pump replaced on advice by my plumber. I have two separate boilers, heat/hotwater systems in the house. This boiler was replaced by a combi boiler as it only heats the lounge and master bed and provides hot water to en-suite bathroom and...
I want to swap my electric shower to a power shower. I have a 200 litre pressurised hot water tank in the loft (not a combi boiler) the hot side has a pump and decent flow, but the cold side/hot side has not got an equal pressure as the cold is just mains fed and would say the flow is below...
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar. Connect to this is a 1.5 bar Ora Salamander pump for a positive head, this was connected by a plumber of course and we’ve had it all rigged up...
Hi, I have an issue with my Grant Vortex internal combi boiler. Specifically the electrical side. Everything was working fine (with a dual channel Hive system) but then the central hearing stopped working. When looking it seemed like there were a number of loose contacts as when we moved the...
1K
    • Informative
Why am I not surprised? Britain’s gas network still using engines from 1960s RAF fighter jets Ageing aircraft turbines will cost millions to replace, says National Gas chief Jonathan Leake14 January 2024 • 5:49pm Mr Butterworth, chief executive of National Gas, says the network is powered by...
