Discuss Shower not getting cold in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. jonsmile
    jonsmile New Member
    hi
    My shower is now not getting cold. It goes from very hot to boiling hot.
    I expect I need to clean/ replace the cartridge. However I cannot work out how to remove the dial from the front of the shower.
    We have a "system-pool" Columbia shower cubicle.
    Pic of dial attached. There is no grub screw.
    Any idea on how to get cold water again/ removing the dial?
    [​IMG]
  2. ShaunCorbs
    I would say new cartridge
    And normally the end dome but either pulls off or screws off
    • Like Like x 1
  3. Darren Jackson
    Darren Jackson Plumber GSR
    As Shaun says above, but also make sure the inlet filters are clean. As this seriously reduces the operation of the shower if they are clogged up. The end domed cap should unscrew or pull off.
    • Like Like x 1
  4. townfanjon
    When you say shower cubical, do you mean the pod type ones ( sorry thats what I call them )
  5. jonsmile
    jonsmile New Member
    yes I mean the pod ones - it is from 1999 and has the steam and jets in it as well as a shower.
    I have managed to unscrew the end dome - thanks to both for the advice - i did not even realise that it was screwable!
    Have now hopefully cleaned up the cartridge - soaked it in descaler. If this does not work, I will hunt for a new cartridge. Any idea where in UK I can get one of these?
    [​IMG]
  6. ShaunCorbs
    @rpm@rpm uou posted a cracker of a link for spares
    Also you can try shower doctor
    • Agree Agree x 1
  7. Matchless.plumb
    Matchless.plumb Trusted Plumber
    Definitely shower doctors they are specialised with shower cartridges.
  8. townfanjon
    I have hunted all over for the valves / cartridges etc for these , ne er been lucky , good luck , you will need it
Loading...
Similar Threads - Shower getting cold Forum Date
Mixer shower not getting hot Bathrooms, Showers and Wetrooms Dec 17, 2017
Is it best to buy a shower tray from the same maker as the enclosure.Will it be a better fit? Plumbing Forum Today at 11:30 AM
