Discuss Servicing Drayton motorised valve circlips in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Backboiler
Does anyone know where I can buy the correct circlip for the spindle on a Drayton motoised valve?
I Did not think that you could strip the Drayton back that far. Just the Honeywell's??
Reply to Servicing Drayton motorised valve circlips in the Plumbing Jobs | The Job-board area at PlumbersForums.net
quality product wanted, my 1/4 turn kitchen sink tap inserts need replacing and i am looking for ones with a spindle gland nut, rather than a circlip which previous experiance says won't last five minutes. as the circlip either weakens or wears out. none of the ironmongery supermarkets appear...
Pete Williams
Hi all, need someone to do my annual gas service and issue me a domestic gas safety certificate. In addition the megaflow cylinder needs checking and anti corrosion electrode replacement (have the part). In addition some of the honeywell motorised valves need replacement.
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't compatible with the new universal one, but the wiring was pretty close AFAICT (N, L, 1, 3 & 4 connected) .When I first powered it up but didn't have any TRVs...
The clock timer on the Mt10rf transmitter does not work, but it can be used in day mode to get the heating on. Is Drayton LP10RF a suitable replacement? I guess the receiver from this would need to be used rather than the existing Worcester one?
