Discuss Scottish Gas Coyboys in the Plumbing Jobs | The Job-board area at PlumbersForums.net
GrahamM
Recently purchased a house. One of the selling points was a hardly used year old heating system installed by Scottish Gas.
After a week I noticed a drop in pressure so decided I better get this sorted before moving in.
I found most of the 30 year old back boiler system still in place including a load of steal pipe that the Cowboys connected up new drops to the radiators to.
There were old leaking isolation valves and some some compression fittings leaking mainly due to not one pipe clip used to support the pipe.
Not one bit of insulation was used to protect the pipework in the ventilated floorspace.
The most shocking thing I found was these idiots splitting floorboards with no joist bellow so they have used a small strip of wood resting on top of the heating pipework to support the floorboard in doorway.
They even put one of their absorbent pads bellow as they know it will eventually leak.:mad:
How do these waste of space idiots get away with it?
I'd complain mate a year is nothing when you look at that workmanship
Bouse Hashers, in and out in 3 hours. Maybe these are the ones who are always boasting how quick they are?
Its been a boiler swap connecting to existing pipework and DIY Dan has been at that board.
Btw check that pipe isn't truewell. If it is rip the lot out.
Reply to Scottish Gas Coyboys in the Plumbing Jobs | The Job-board area at PlumbersForums.net
