Discuss Santon Premier Plus - Unvented Hot Water System in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
LC_home
I have a Santon Premier Plus - Unvented Hot Water System installed in my apartment and it seems the timer has stopped working. I have changed the timer which seemed to of fixed the problem but a month on the same problem is back. I currently use the 'Boost' button to heat up water.
Originally the plumber thought it was the thermostats so we have changed those already. Now the electrician and plumber are not sure what the problem is. Anyone got any ideas?
With respect, you need to find more competent tradespeople. They are letting you down. It is not possible to remote diagnose realistically.
Good luck
Good luck
Yes I have to agree with”sweetlips”above .
Sparkie needs to see if the timer and stats are working , it will be one of those .
Have you put quality stats in ? , because some are beyond garbage, mind you so are some of the timers .
Reply to Santon Premier Plus - Unvented Hot Water System in the Plumbing Jobs | The Job-board area at PlumbersForums.net
