Discuss Saniflo drainage issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello not sure if this is the correct category but hope you can help.
Installed a saniflo for downstairs loo and Basin but client says its making (new noises) The pipework runs horizontal from the top of the saniflow for 60cm - straight down under joists around 60cm- then horizontal for about 3.5 /4m into stack
Anyone assume any problem with this setup?
thanks
Ok so ill put an anti siphon on the 1st horizontal section.
Any other suggestions or is the design ok in general?
If the last horizontal falls by a minimum 1:100 then No.
(Didn`t read all of the post this morning).
Can see why SimonG said syphoning however that would of shown up within the first few flushes. As a "New noise" my £`s is on wet wipe(s) which accounts for +90% of all my call outs.
Reply to Saniflo drainage issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
