Discuss salmander shower pump installed problem :-/ in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. peter0504030201
    peter0504030201 New Member
    hi all
    installed a Salamander Pump 100 TU negative and positive head , each side side of the pump as red for hot a blue for cold water connections , but I have just realized I have fitted the wrong way round , would this be a problem for the life of the pump ?
  2. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    What do you mean. You have piped hot to blue and cold to red?
  3. peter0504030201
    yes that's right
  4. Harvest Fields
    Turn them around. They are marked like that for a reason mate.
  5. peter0504030201
    hard to turn them the right way now , this job was to resolve a complaint through my company , being a whole house pump with bypass tubes going from hot to cold impellers I cant see any issues with connections being the wrong way , the heat will travel to both sides when in operation , I just wanted to hear what other people think?
  6. Harvest Fields
    And I have just told you. But your the one that will have to fix it when it breaks down so you do what you see fit mate. It was just my opinion.
  7. Riley
    Riley Plumber GSR
    The key with it being piped wrong is that you give the manufacturer a get out if it fails within warranty
    • Agree Agree x 2
  8. SalamanderPumps
    SalamanderPumps New Member
    Hi, if you need installation advice please call our technical team on 0191 516 2002. Thanks.
Loading...
Similar Threads - salmander shower pump Forum Date
Cable to an electric shower Plumbers Arms Monday at 6:32 PM
Looking for mixer taps with shower attachment unusual size. Valves & Taps Sunday at 10:35 PM
