Discuss rothenberger or hilmor bender? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
cosworth*mad
I am at college and we use both (15mm&22mm). Being a novice i can't tell a good bender from a bad one but want to buy a quality tool. The college tutor recommends a hilmor, and only a hilmor, even stating that the rothenberger bender was poor. However now i am researching, rothenberger seem to have a repuatation for good quality tools. Any comments/advice. I have come acros this deal which seems good? what do you think? Thanks Rothenberger Superfire 2, Bender, Pipe slice, Gas 5 Pcs on eBay (end time 26-Dec-10 18:01:33 GMT)
i bought a 2nd hand wickes bender from a steam fair ,works perfectly well for me ,lol,cost me £12
Rothenberger don't actually make tools. They rebrand and sell under their own name. Their benders are similar to Record but can't be sure. Decent enough stuff.
tamz , i would beg to differ on that one as i dont think rothenberger benders are anywhere near as good as record , in fact i think rothy tools are on a par with draper . just my thoughts .
Cosworth if i needed to buy benders it would be the hilmor even though i have had some record benders for years . cheers mark
Hilmor benders, Rothenburger torch, monument pipe slices and bahco spanners.
Oh - Stanley knife but that's also because one of my names is Stanley!!
Have both record and hilmor in my kit found rothenberger heavy by comparison but the pair I tried had the advantage of being able to set 12mm pipe as well even came with 12 mm guide not a lot of call for 12mm though!:)regards turnpin
You may be correct Billy. As i said i can't be sure. Record do good stuff but i've never had one of their benders for many years. The Rothy bender is ok but the Hilmour is generally regarded as the best.
If you can afford it, get a stand up machine. Much better bends than any hand bender. Just heavier to carry.
benditnow, conduit and copper pipe bending machine specialists - Home
Hillmor, I really havent liked anything rothenberger that Ive bought over the years.
hilmor m8 and a rothy tourch and the deal on ebay for the cutters
as i got screwed over on ebay last week selling some bits and some one not paying
i didnt get a chance to get my hilmor benders gutted
and there was a cheap set on there screwfix ones got them for a tener
they will do for now till i get this ebay thing sorted then ill have a nice new set of hilmor benders
and keep the cheep one in the lock up as a back up lol
iv used rothy benders and cheep sets and hilmors its down to self pref m8 use what you fill good using but for me its hilmor
all the wall even if you offerd me a new set of each now id take the hilmor benders hands down i made
the bigest mistake of my life once i found a used set of hilmors in a skip forms the lot used twice sold a load of tools out the lock up cleard the lot out and the benders was in the lock up
when i get my new set im locking them in a van volt
Does anyone use stand up machines anymore or are we a dying breed?
Even your cheapest 2nd hand stand up will do better more accurate bends than any hand bender.
I used to take a 20ft length (you can still get them) of pipe out to the bender. Put half a dozen bends, saddles, and offsets on it and take it in.............couldn't get it in the bloody door!!! so had to cut it, usually into 3. Still looked the dogs when it was up tho.
Stand up for me Tamz , when I can . Usually in and out of houses its the hand bender but the floor bender is out quite a bit now with 28mm gas lines.
Nothing worse set up the bender pull the bends etc and have to cut it up !! LOL been there (more than once !!!)
That's just showing off! :cool:
A fast tracker like me has NO chance!!!! :(
Good on ya though. Hope you keep that skill ... you lucky blighter!!! :D:D:D
haha you can take a boy off a site but you cannae take the site out of a boy
i remember when i was a boy the guys used to set up a wee book with all the sizes marked down for the pipes you are on about, left hand and right hand houses, excellant way to do a full site, after a wee while the sizes didnt need to be checked in the book, it was a joy to bend up something say cylinder draw off/vent from the top of the cylinder right up into the loft and over the tank, as you say the hardest bit was getting the stuff in the door and up the stairs
I have a rothenberger and it always leaves a "V" mark on inside of bend. It is difficult to avoid making creases as well. 'Record' are very good and i can't say anything about the Hilmor as haven't used one.
rothenberger benders, pipe slices, box spanners are s##t. don't rate much they do apart from their grips
Hilmor, but not an Ebay knock off.
Just remembered a joke we played on an apprentice a few years ago - gave him a 28mm bending spring and a length of pipe and told him to put a bend in it.
Ive got a set of Rothenburger scissor benders absolute rubbish compared to Hilmor they keep rippling or even kinking the tube, Ive also got Rothenburgeger tube bender maxi these are the dogs wouldn't be without them.
Done that one a few times. Not good for the knees so pull it around something.
When i was serving my time there was a 1 1/4" spring hanging in the yard but i never saw anyone brave enough to use it.
In my experience, the Rothenberger benders are tricky for a big 22mm bend as the arms ar closer together and the handles a shade shorter also. I have used Hilmor which are superior in my opinion. I now always use an old set of Record benders, which are exactly the same detail as the Hilmor. They cost me 2quid and are so well used the raised numbers and marks on the formers are worn away and all paint has gone. This 'wearing in' now means every bend is physically easier and perfect each time.
I would definately go for Hilmor
Andy
We also gave another apprentice a hilmor bender and some 1/2" steel pipe and asked him to put a bend in it!
My van is a Defender and a tip I was given long ago is that the jacking holes on the front bumper are exactly the right size to hold some 28mm pipe with a spring inside. You can pull slight bends easily with it.
I had some 1 1/2" copper to bend once - I took it to the car exhaust shop in town and he did it on his exhuast bending rig!
Hilmor ive had mine for 7 years up in this b**ch and still just as good if not better
just bought a brand new hilmor the other week still havent used it yet but I prefer the tripod benders to be honest more used to them but obviously they are much dearer and more hastle if your not on site anyhow
Reply to rothenberger or hilmor bender? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
