Discuss Roll and stroll (or whatever its called) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Millsy 82
Normally I usually put dust sheets down and with stair rods are brilliant but on longer jobs I spend 20 minutes each day covering stairs/ hallways etc so I don't damage the carpet, so if I am there for a week that is 1 hour 40 minutes lost doing that.
I am thinking of using roll and stroll so I can leave it down overnight.
Is it slippy with only socks on as I don't fancy getting sued for slipping down the stairs.
Not slippy at all, we use it all the time great stuff, some rubbish ones though that don't stick at all,
The stuff from Grahams seems ok but a plasterer on a recent job had some yellow stuff down and was really tough stuff. Dunno what it was called tho!
Think the yellow might be made by hippo
Funnily enough just watched the YouTube and first time I used roll and stroll I cut it with a Stanley knife, right through the roll and stroll and the bloody carpet!!!
:D someone pressed too hard
I use the no-nonsense stuff from Screwfix. It says it's for hard floor but it works just as well on carpet in my experience.
I love roll and stroll. Great on stairs and long hallways. I leave it down over a two day job and had no issues. The only trouble is if you put it on a carpet covered in cat hair it leaves a perfect clean strip afterwards!
When this first came out I think it was rhino roll or something similar and am sure it was around ÂŁ60 per roll,
I use the yellow stuff too. Can't fault it. I pay around ÂŁ30 for a 50 metre roll from my local merchants.
Roll and and stroll is yellow and has a non slip texture to it, works really well.
I get it from tool station for less than ÂŁ15, customer think you're awesome as well.
Roll & Stroll Protector Carpet - Toolstation
By the way, it says 20mtrs which is a typo, it's actually 25.
I've used some of the other slightly cheaper ones and you end up spending hours trying to get it off the roll without it ripping, or taking the creases out of it!
Pretty sure it has to come up after 7 days or it can damage the carpet, might be wrong.
I looked at it once but was scared off by some poor reviews on screwfix of a strip left on customers carpets where the roll was layed, this was on new carpet, that even carpet cleaners could not remove! Plus it says dont use on wool carpets... Too risky for me, I ain't forking out for new carpets!
They leave a strip behind sometimes but i find its where the carpet is really clean compared to the rest, because it's picked up dirt and dust out of the carpet.
You can see where they've been, depending how clean the carpet is and how long it been down for but I've never had a customer complain. I've been using it myself and with other people for around 3/4 years.
I don't know what make mine is though, it's not made by roll and stroll.
Reply to Roll and stroll (or whatever its called) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am generally a decent handyman, can usually make 2+2=4 and take care of most things to avoid troubling experts with just the basics, but know also not to bumble around blindly beyond that. We moved house last week and with the glorious hot weather we weren't bothered about the heating, more...
Hi All I tried posting this already and lost post so here goes again. I'll start from the beginning so please bare with me. Few Months ago I was getting intermittent heating with occasional flame error code on my ICOS HE12. British gas engineer came out when the system was working and...
2K
Hi, I have some knowledge of plumbing and heating and have installed several in my time. I have a new Worcester Bosch Greenstar 40CDi Classic Regular Gas Boiler (Gravity Fed System) new boiler and it was installed by a British Gas engineer recently, as I wanted a Gas Safe certificate with this...
2K
Hi folks. Sorry this is a long one. I'll try and keep it organised. Son has just moved into a purpose built (2013 ish) 4th floor apartment as a tenant. No gas in the building. Triple glazing. 1. The letting agent led him to believe that the electricity supply was on an Eco 7 meter. He didn't...
5K
  • Locked
I'm hoping for a bit of advice. We are in the process of renovating an old house and as part of that work we are upgrading the old 1980s boiler and gravity fed system with a new boiler and unvented cylinder. I got a load of quotes, went for a guy we thought seemed ok and checked that he was...
4K
