Discuss Riello motor stopping or jamming in the Plumbing Jobs | The Job-board area at PlumbersForums.net
riksony
registered plumber
What causes a burner motor to jam on start up. Give the fan a push and away she goes.
The capacitor might be gone and needs replaced.
Sometimes a tight motor or oil pump can also damage capacitors.
That really should be checked at each service and replaced if motor hasn't a split second quick start up.
Reply to Riello motor stopping or jamming in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm looking for some advice on a frustrating problem I'm having with my old Eurostar 50-60s oil boiler please? Although it's old, most parts needed to operate it are now new. The symptoms indicated a broken/seized burner motor or oil pump. I wrongly assumed the motor so I ordered a new one only...
Hello, I'm a homeowner, not a DIYer. I have an almost 1 year old SaniCompact Comfort wall-hung toilet which has worked flawlessly until about a month ago. The last couple of times it was used, it made a loud noise and acted like it didn't want to flush. I guessed that it might be time to...
Hi. I have a firebird enviromax combi boiler. each time it turns off the motor on the riello burner keeps running for a while then the whole thing goes into lock out. flashing green and red. shouldn't the motor turn off straight away? I'm also getting pressure building up while it's running...
3K
Worcester Boiler. Really annoying. All works as it should fine in normal use. However have to go away for a couple of weeks at a time. I put the boiler in holiday mode 5 degrees it's very unlikely it's needed to kick in. When I come back the boiler pump motor is often running even though it was...
Bosch Sauce
I have a conventional system, Potterton Prima Boiler, into a Pump into a Motorised Valve that feeds the Radiators and/or the pipes in the Hot Water Cylinder. Analogue Controller with slide switches (replaced 2 years ago) and analogue Room Stat and Hot water cylinder Stat. I'm just an amateur...
