Discuss Revision help for level 3? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Curlyn
Whilst revising for level 2, I had the JTL disc and learnatrade disc. Both I found helpful for testing myself after hours of reading/making notes etc. I have cold water including water regs (level 3) coming up soon, and was wondering if there are any trial questions/discs that are geared to level 3 around? Or, how did you revise for these exams?
water regs should not be a problem if you have the correct notes in your regs folder, as for the other level 3 exams there is a good JTL revision book out, i also i recommend the treloar nvq 2 & 3 book.
There is also a system planning written exam that is a nightmare, really hard and very unpredictable.
As for question discs, your on your own this time.. the learnatrade disc is still helpfull as its all done on computer now and you find questions from level 2 popping up from time to time.
Good luck!
Reply to Revision help for level 3? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
