Discuss Review: Irwin Mini Hacksaw 24Tpi 12" (250mm) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
would this be any good?? It is a Boa Versa saw, the blade is attached at hand, and slides out the front when you push the handle forward, and a spring returns the handle back??
Hmmm, quite possibly. Cheers.
Checking a promo vid out now... BOA Versa Saw - YouTube
My old man got me one, best part of 9 yrs ago, I think I only have used it once, reading this thread, made me go and find it in the shed to see if I still had it. I used it on removing a set of mono sink mixers where the tails were to close to get a slice on, did the job nicely.
Seems ideal, if not I'm going to invent my own. Thanks again, definitely one to try out. :)
Anyone got a link to this particular multi tool you're all raving about?
If you want to saw the back board get a stanley padsaw blade and flatten it into a bit 15mm pipe for a handle. It is better at cutting wood than a hacksaw blade.
I use my cordless multi tool for everything now. Binned the hacksaw blade ages ago.
Yes I was using my Fein today cutting a load of lead out, the old saddle clips were all painted up so I wipped through them with the Fein in no time. Had the green Bosch but it didn't last.
My review was accepted, suppose I should have read the other ones before buying it in the first place.
[DLMURL="http://reviews.NoLinkingToThis/5873redes-en_gb/DisappointedKeefy/profile.htm"]DisappointedKeefy's Contributions[/DLMURL]
Reply to Review: Irwin Mini Hacksaw 24Tpi 12" (250mm) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
