Discuss Replacement diverter valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Robert Tyrrell
I know that everyone is likely to be really busy but if anyone has a suggestion that might help my customer, I'd appreciate it.
The problem is this:
My customer has an old Worcester Heatslave 20/25 and the diverter valve has packed up this morning causing the bier to overheat.
I have tried, without success, to locate a replacement diverter valve and my customer needs the boiler to work until January when the house is being demolished to make way for a new development (They are moving elsewhere
(Valve-diverter 22mm679b31648lo).
My question:
Does anyone know of a replacement diverter valve that would work?
Is it the old acl valve?
If so you can fit a Honeywell 3 port 002. But reverse the a and b ports.
Replaced the actuator, and the pump head (It was locked solid) but now I get hot water, just nothing on the heating side. I've checked the diverter wiring and I get power to the white and orange with the heating, and power to white and grey on hot water. The boiler did get damn hot last night and the burner shut down (lots of hot air vented from the boiler by me, but no burner lockout).
The OHS hadn't popped the button so I asked them to leave it off overnight and try the heating this morning - they have HW but not CH.
Scratching my head right now as I'm on an install that has to be finished tonight.
There are three air vents on boiler, radiator style key.
Can you open diverter with lever and see if heating works?
I'm not on the job at moment but I sort of recall it working with the lever pushed over on the diverter.
I'm going back on Saturday morning to have another go though.
Where are the other vents then? I could only find one, at the front of the boiler.
One on top of boiler, front left, other two on copper pipe from water heat exchanger but if hot water ok these poss clear of air.
Reply to Replacement diverter valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
