Discuss Replace existing shower and shower door in Carlisle in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an existing exposed shower valve and riser which I need to have removed and replaced with a new exposed valve and riser. Also the shower door (across the shower cubicle access) needs to be replaced. I will procure all fitments, so labour only required. The job is in Carlisle, I suspect less than a days work, non-urgent so can be flexible on timing.
Reply to Replace existing shower and shower door in Carlisle in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
