Discuss Remove plaster and silicone from cast iron bath? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Groppo91
    Groppo91 New Member
  2. rpm
    rpm Trusted Plumber Top Contributor!!
    Silicone remover and a sharp wood chisel, gently gently as you go.
    • Like Like x 1
  3. AMGasServices
    AMGasServices GSR
    And remove the plaster with a stiff brush using a fairy and hot water solution. In small patches.
    Use a dry cloth to dry the area once it’s spotless move on to the next patch.
    Regularly cleaning washing the bursh.
  4. king of pipes
    king of pipes Trusted Plumber GSR Top Contributor!!
    No easy way needs a good scrub and elbow grease, a product called Bar keepers friend will remove stubborn stains . Cheers kop
Loading...
Similar Threads - Remove plaster silicone Forum Date
Need to find out how I can remove soft-close top fix toilet fittings? Fittings & Pipes Sep 10, 2018
