Discuss reducer 50mm to 42mm Needed Help? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Picanco
Hi
An Old Jacuzzi's, pump replacement need a reducer for one of the pipes:
Solvent based UPVC from 50mm to 42 mm - I have not been able to find these at all. Can anyone help, where can I get these?
they are pressurized fittings, try any industrial supplier, if you get stuck pm me and i will arrange to send you one
Hi
as mico said these are preasure holding plastic fitting as used on swimming pools you need special adehsive for these as well and you must not turn the fittings when you join them
i have seen some on ebay under swimming pools stuf
or try a wolsey plastic center
there are a lot of funny sizes in this stuf both imperial and metric and it also comes in two types of plastic white and grey
Reply to reducer 50mm to 42mm Needed Help? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
