Discuss Ratchet spanners in the Plumbing Jobs | The Job-board area at PlumbersForums.net
novicegas
Hi guys, am looking for a pair of ratchet spammers, seem to remember there being a link or thread on here about them, they're about £45-£50 big solid silver ones that look like pump pliers it have smooth teeth' like a set of adjustables,cheers
Your link didnt take me to the product on my phone. I assume you were linking to these
Those are the ones, anyone used them? They look good if a bit pricey!!
I have 2 they are great, as an avid quality tool collector I do not regrett buying them. Do I use them every day? No. Are they expensive for what they are? Yes. Will they last forever? Probably. Keep in mind the max jaw opening limits the possible applications in which you can use them. There are different sizes. They have considerable clamping strength. Great for holding valve bodies while tightening compression nuts or for mixer valve unions. The flat faces mean you can avoid damaging chrome finishes. If I recall correctly I can get mine over meter unions but not much bigger than that.
thats a big meter union ;)
i love them, i'll buy myself another set :)
go for the larger set imho
Knipex Kpx8603300 4003773040927 Plier Wrench Cushion Grip 60Mm Capacity 86 03 300
and yes, its 12 at night and i'm still working.....
You are quite right I tend not to use mine at the full limit as your pic shows which I should have made clear. Mine have different grips though, thicker moulded rubber in blue and red. Kudos for the quick pictorial response.
i think the blue and red only go upto 46mm. the red ones go up to 60mm on the larger size
great tools, the flat jaws don't do them any harm unless you want to grip tube.
Stupidly used mine to put a rad tail in once and crushed it but rad tails are half tube half fitting and it was a cheap trv. Wont do that again.
Reply to Ratchet spanners in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
