Discuss Ratchet pipe cutters in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Barry98
Who's got some what they like what make , Steve haven't you just got a set
Copper or plastic? them 7 quid ones from TS are ideal for plastic pipe upto 42mm, last ages and are cast aluminum
Which ones ?
RATCHET PIPE CUTTER (6-28mm)
Category: Store
> Tools & Equipment
> Hand & Misc Tools
SKU HB01
In stock
£16.50
This price includes taxes:
Qty
Add More
Go to Checkout
Powered by Ecwid
View detailed images
  • Heavy-duty, professional ratchet pipe wrench.
  • Fitted with ergonomic contoured handle for added grip, ideal for use in confined spaces.
  • 2-in-1 Feature allows ratchet head to be removed for use as a standard hand pipe cutter.
  • Robust ratchet head features fully adjustable blade positioning providing a cutting capacity of Ø6-28mm.
  • Features a hardened and tempered cutting blade which easily cuts through copper, aluminium and brass piping.
  • Fitted with hanging hole
Category: Store
> Tools & Equipment
> Hand & Misc Tools
SKU HB01
In stock
£16.50
Qty
Add More
Go to Checkout
Powered by Ecwid
Tried them, needs loads of room around the pipe with thses
yes indeed i do have a set thank you very much simon. i haven't had the opportunity to use them as yet but i will put a review up when i do.
I got the nerrad set from corgi direct a couple of months back.
not really had need for them as yet, they do require more room than a standard cutter, but with the benefit of not needing to get the hand in aswell
am more interested when the pieps are under the floor and against the joist and you cant get your hand in
Bod, monument do a lever to attach to their pipe slices which looks useful. I normally just use my pump pliers
sorry for the delay, i didn't need to use them in the end. it was a sink and tap change and the person who had gone before had put iso valves in so just needed adjustables to swap. didn't even need to change aperture in worktop new sink slotted straight in, how many times has that happened?
Reply to Ratchet pipe cutters in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
