Professional Plumber Required Radiators on when heating on!?
Discuss Radiators on when heating on!? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
targett
I have a keston 25 boiler and a megaflo hot water tank.
When my hot water is on at the control unit/timer I have hot water and heating activated despite the heating being off at the control unit/timer...
I've checked the valves and the actuators in the airing cupboard (1 for heating and 1 for hot water) and both are working mechanically and electrically but still the heating comes on.
Any thoughts?
Sandy, Bedfordshire.
Sent from my Desire HD using Tapatalk
Reply to Radiators on when heating on!? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that has previously been extended. In one of the bedrooms that has been extended there are 2 radiators, one which looks like it was fitted when the...
G
I've just bought a 3-floor house with a gas boiler on the ground floor and hot water tank on the middle floor. When I switch on the hot water at the timer panel, it works but it also heats up all the radiators above ground floor. I have to close them individually to stop this. The rads aren't...
Hello, I have a customer with a modern anthracite vertical radiator and a modern TRV and lockshield. The radiator makes a loud metallic bang from within the radiator, when it heats up and cools down. I have opened the lockshield fully, lowered the boiler pressure from 2.5 bar to just over 1...
My son has just had a new boiler fitted and hes noticed that the pump runs 24x7 even when both the heating and hot water are set to off. He’s also found that when the hot water is set to off on the programe timer, the boiler is still heating up water. I wonder if this is because the engineer...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that heats on controlled load over night. The large tank is in roof space of 60s built villa unit. Every few mornings, no hot water will come out of...
