Discuss Radiators hot upstairs, stone cold downstairs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, I'm looking for some advice on my central heating. We moved into a house with an 'Exclusive ProCombi 24' boiler about a year ago, and it's been working well up until 2 days ago. Some radiators were warm rather than hot, so we bled the radiators. This caused the pressure to drop, so we upped it to 1 and a half where we believe it shold be. However we noticed then the following day that every radiator downstairs was stone cold, while all the upstairs radiators were boiling hot - except one radiator downstairs in the kitchen which was slightly warm.
We bled all the cold radiators which didn't help, but I then saw a YouTube video of how to open the pump and 'loosen' the spindle/mechanim. After unscrewing the pump bleed screw, hot water was leaking out as expected. I then tried turned the spindle with a flat head screwdriver a few times to ensure it's loose, and after putting it back together tried the heating again but it unfortunately didn't make a difference.
I'd like to exhaust whatever diagnostic options we have before paying for an engineer to take a look, so is there anything we can do to attempt to fix it or diagnose where the fault is? The pump itself is hot too the touch, and you can feel low vibrations which I'm hoping is good news!
Thanks - might be worth noting the boiler is downstairs, so I find it odd that upstairs work but downstairs doesn't
As it a combi boiler best to get a gas safe engy to replace the pump
Reply to Radiators hot upstairs, stone cold downstairs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. Turned my heating on for the 1st time today, i bled every radiator as haven't done it since last winter. upstairs worked fine but an hour or 2 later I noticed downstairs was still cold. I looked for some advice online and turned the trv's off and locksheilds for the upstairs only and...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was not working. He changed both valves and still the radiator was not working. He put some chemicals in and said it should break up anything that is...
R
Hello its my 1st post hope im in the right place We brought a new house a medium-large 3 bedroom semi, we moved in the summer. Now coming to winter we started putting the central heating on. The central heating has a mind of its on it’s really strange iv never experienced this We put the heating...
M
Hi, I woke up this morning with cold water (mains) from downstairs tap but no hot water from downstairs tap, and no water at all from all the upstairs taps, I have a combi boiler and no water storage
Mike Young
M
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are about to upgrade the upstairs bathroom and are considering installing a shower bath. My concern is that although there is more than sufficient...
