Discuss Radiator face plates in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
F49h
hi Guys N Gals
Does any one know if you can get a 15mm radiator face plate, I can only find ones for 10mm.
Cheers
Reply to Radiator face plates in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, I need to replace a radiator in the kitchen, the 10mm copper has split so using this opertunaty to replace it with a towel one and also need to remove both valves and make the pipes shorter. Its a gravity fed system and the last radiator in the system , I have a bung kit, i know i can...
Hi guys, These sleeves cover 10mm PVC central heating pipes (see picture and ignore tape measure) and I believe this is what makes it possible for the 15mm nut and olive to attach to take the radiator valve. As you can see they are installed before nut and olive. I've ordered a black towel...
Hi all. Could someone help with a issue I have been having with my vertical radiator. I have one vertical radiator in my bungalow and it does not heat up unless the surrounding radiators are shut off. I have tried turning the surrounding radiators down but the have to be completely or very...
Hi to all, I have bought a new radiator as replacement for old one. After installation by plumber, the new radiator is heating up only to 1/3 of high. The rest remain cold. Also, radiator is making quite loud noise when heating up. The system/radiator is free of air. My plumber was...
Hi, I'm looking to add some radiators into my property and ideally looking to match the style of the existing ones. I cannot seem to find anything online to match. I assume this style of radiator is no longer manufactured, but I might be able to pick one up second hand. Can anyone help me...
