Discuss Question re: an old Worcester 9.24 electronic boiler and upgrading in the Plumbing Jobs | The Job-board area at PlumbersForums.net
booroo
Howdy all,
my flat came with a worcester 9.24 boiler and it has served us well for the past 8 years. The only hiccup was when the fan needed replacing about a year ago. It also requires a reset (unplug from the wall for 10/15 minutes) very rarely (perhaps four times since we've had it). Apart from that, it has served us very well.
So...my question is this. We applied for, and got, a £400 voucher as part of the London boiler cashback scheme but due to a few difficulties we've not gotten around to being able to use it yet. Bearing in mind how old the boiler is, should we take advantage of this voucher and replace the boiler sooner rather than later? I'd really appreciate some opinions on whether or not those of you with experience think that we're running on borrowed time as it is or whether you think that if it has served us well so far it likely will continue to do so and whether or not any issues will likely be easily dealt with (such as with the fan).
I guess the bottom line is that we'll be spending £1000+ to save £400 when we currently don't really feel that it needs to be spent in the first instance. Any advice on this situation would be greatly appreciated.
Howdy all,
have you had it serviced every year?
looks like some of the parts are now becoming obsolete. Might be time to take advantage of the £400 voucher and have a new efficient A rated boiler installed with controls. If you get something with a 10 year guarantee then this would give you piece of mind as long as you have it serviced every year by a gas safe registered engineer. Plus it will be likely you will achieve a saving on your gas bill which over the span of the 10 year guarantee would end up in the boiler paying for itself.
Got called out to one of these two years ago, fan had failed (very common part for any boiler), no longer available as a spare!
Bottom line is: Keep hold of it if you want, but don't moan to the breakdown eng who comes out one Xmas eve and says "you can't get the part"...
Reply to Question re: an old Worcester 9.24 electronic boiler and upgrading in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler. Initially we thought the boiler may stay in place but after discussions with the builder we would have to move the boiler to replace the floor and...
T
I’m currently looking into replacing my 20- year-old Ideal Classic FF 360 gas boiler in a 70s semi and have been getting various quotes for a condensing conventional boiler, as we don’t want a combi. The current boiler works well, we have it serviced every year via British Gas Homecare, but...
2K
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
Hello, My mum has a Worcester Greenstar HE30 boiler (15+ years old). Since its last service (and possibly coincidentally) it has been making a booming/banging sound randomly. This is a noise like a pocket of gas igniting and can be loud enough to make you jump. It's been impossible for the...
2K
I'm sure this is an old question but here goes. I'm looking for some advice regarding switching from a conventional boiler to a combi. I moved into my current house about a year ago. It has a conventional boiler with a hot water tank. The boiler is Vitodens 100-W, which is a condenser boiler...
1K
