Discuss Qualified engineer with G3 unvented ticket - Gravesend Kent area please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good afternoon all
Are there any G3 un-vented cylinder engineers in or the near Gravesend, Kent please? Details of possible issue below:
The boiler won't call for hot water but does for Central Heating. I have a Heatre Sadia unvented cylinder with two no 2 port zone valves (one for CH and one for HW). I am only able to get hot water from electrical immersion heater so not ideal at all. Here is an excerpt of what I have been doing below but to avail!
When I turned the central heating on, I manually moved the lever arm across on the 2 port valve on the primary flow. This then allowed the hot water from the central heating to divert through to the coil in the unvented cylinder. That's why I was wondering if the head gear (or all of the valve) was knackered on the 2 port valve(s).
I have set the programmer to see if it calls for heating and hot water by day and times . If it only kicks in for heating do you think it'd be the port valves?
Thanks gents for all your help and advice. The digital programmer is kicking in for the CH but not hot water. I have got a volt detector pen and there is power in both black cables going into each of the respective 2 port zone valves so might be the Honeywell digital programmer? The programmer is a Honeywell ST6400C programmer and the 2 no 2 port zone valves are Honeywell, too.
Someone mentioned it could be the cylinder stat tripping?
Anyway, seeing as I don't have a G3 ticket I would rather someone who is qualified with a ticket to come round and give me a quote.
Thank you very much and please get in touch.
Martyn
Reply to Qualified engineer with G3 unvented ticket - Gravesend Kent area please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I have an OSO Direct 210 hit water cylinder installed in my home, with 2 switches (on/off; and boost). The boiler is for hot water only (rads are electric). In the 5 years that I’ve lived at this property, I’ve never once turned the boiler off; however, with soaring energy prices, I’m...
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from the shower but it seemed no different from the original combi boiler hot feed. There is (unusually) a lever that lets me select the combi or the...
Steveo111
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or pressure dropping with unvented hot water cylinder system. During summer time there is no usage of central heating so the pressure at unvented system is not...
Looking for a gas safe engineer to complete a boiler and cylinder install in Ringwood BH24. There was a delay of approx 8 months from the install to radiators being fitted and therefore able to comission the system. Our plumber is now employed elsewhere and unfortunately unable to complete this...
Good Afternoon all, I am hopeful someone may be able to offer some guidance on the following. In the home we have a gas boiler (serviced annually, October time) providing hot water to the CH system which is split into 3 zones (Honeywell 2-way valves) and it also heats the HW tank (Tribune...
