1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Dismiss Notice
Couple of important things to note. 1. We use Cookies, deal with it. Every website does. 2. Nobody but a currently-registered Gas Engineer should be touching gas or gas appliances. Don't mess with gas at all.
Discuss Pvc cladding.and tanking in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Ant6869
    Ant6869 New Member
    Hello all,
    Wonder if anyone can advise this may be a crazy question but i will ask anyhow, is there any point in a belt and braces tanking of shower walls if using waterproof wall cladding as opposed to tiles.
    Look forward to opinions.
    Many thanks.
    Ant
  2. ShaunCorbs
    ShaunCorbs Trusted Plumber GSR Top Contributor!!
    I do / would can't harm
  3. PlumbBobBob
    PlumbBobBob Guest
    belt and braces is always good
  4. Ant6869
    Ant6869 New Member
    Thanks for the replys, i am a belt and braces kinda guy and thought it would be a good idea to tank first however the supplier said dont bother as the sheets are 2.4 x 1.2 and there will only be a joint trim in the corner and a joint where it meets the tray so the whole job is done in two sheets, i then spoke to both dunlop and then bal regarding this and they tell me their tanking kits are for tile adhesive and they were not sure if the adheasive used to fit the cladding would bond correctly to the tanking and even if it did couldent gaurentee the longevity of it.
    I am now very confused as i thought all on here would say the same.
    Help please.
    Regards
    Ant.
