Discuss Pump cycle Vaillant in the Plumbing Jobs | The Job-board area at PlumbersForums.net
On the vaillant ecotec plus's under the installer level and program checks there is an 7.5 min programme called pump cycling which you can runderstand on your hot water or heating circuit I know what it dose ect ect bleeding the system of the air.
The reall qestion is how dose it work just a curious engeineer if anyone could she'd some light please go ahead!
Thanks.
Exactly as you said. It clears air from the boiler heat exchanger ( not your system) it opens the diverter valve ( combi) to clear any residual air from that too. The pump, turns on and off a few times to let the air rise to the auto air vent built into the boiler.
As I said it will not clear air from your entire system.
Reply to Pump cycle Vaillant in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for heat, the boiler fires up, modulates, but jumps very quickly (about 30 seconds or so from 40'ish all the way to 70, burner disengages putting it the...
Good morning, wondered if anyone can advise please on a resolution? My set up at home is that I have a 4-bed detached with 21 radiators (includes 4 towel rails), a 6m x 4m orangery/conservatory that was built last year with under-floor heating, and a Megaflo for storing hot water. The UFH...
5K
We are experiencing an issue with CH short cycling on a Worcester Bosch Greenstar 25i ErP boiler. From a cold start the boiler fires for only ~25 seconds before exceeding the set CH flow temperature and entering it's 3 minute short cycle programme. As soon as the short cycle programme kicks in...
1K
I have a question that I’m hoping those of you who are experienced central heating engineers may be abler to throw some light on. But first I need to tell you about my system, and the problem I’ve been having. Just over 7years ago I had a new CH system installed in my small semi. I say new – in...
Vaillant ecoTEC Plus 400 15kW Heat Only Boiler I've got air in the pump and one gas engineer has said I need to move the pipes as they are configured incorrectly. Another said all I need to do is add an AAV as high as possible. Another said I should seal the system. Boiler was installed in...
