Discuss Protect new power shower from scale? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Jennie
    Jennie GSR
    Hi all,
    I'm due to install a power shower, in a hard water area.
    Currently, the property has a 'Water Elf' electronic water conditioner on the cold mains by the stoptap.
    The home owner would like a water softener fitted. The only place it could go is in the kitchen cupboard by the stoptap (access to the cold water pipes and to run the overflow and drain connections will be a bit of a pain, but not impossible.)
    So...
    Is the water softener the most advisable solution? Or will the Water Elf (or a different magnetic treater) suffice?
    Thanks for all your advice,
    Jennie
  2. Matchless.plumb
    Matchless.plumb Trusted Plumber GSR
    Hi Jennie,
    Me personally,I asked those questions recently too and the engineers would rather install a softener than an inline scale reducer. These scale reducers use the principle of electrolytic action to alter the characteristics of hard water. Lime scale will just pass through a domestic system without sticking to the heat exchanger but I wouldn't really say they work 100%.
    You are better off installing a softener. I have recently installed the one from Harvey. Excellent piece of kit. Perhaps you could use a condensate pump in case you don't have a waste near by.
  3. rpm
    rpm Trusted Plumber
    I`ve yet to hear good things of one of those inline magnet things, also some boiler manufactures say No to softened water going through them so bear that in mind.
    • Agree Agree x 1
  4. Matchless.plumb
    That's true I had to make sure before hand if the Harvey unit is compatible with the boiler etc.
    The unit is compatible with all type of boilers and it's drinkable too unless you are on a low sodium diet or you've got a new born baby under the age of 6months old. If you want you could bypass the boiler or have a separate hard water link.
  5. Jennie
    Jennie GSR
    That Harvey unit sounds interesting. The property has an old, Baxi floor-standing boiler.
  6. rpm
    rpm Trusted Plumber
    Was under the impression that the kitchen tap had to bypass the softener, stand to be corrected by more experienced people though.
    • Like Like x 1
  7. ShaunCorbs
    Yep your right rpm, Ron I've told you a week ago kitchen tap and an outside tap needs to be unsoft
    And the boiler rule only comes into play if it's a combi or sealed system
    Which the ops isnt
  8. rpm
    rpm Trusted Plumber
  9. Matchless.plumb
    I have split that off but there is no regulation to have a separate hard water pipe to the kitchen tap or garden tap. I have spoken to Harvey and got that all on email, however I have not installed the whole house under the softener but it would work and it wouldn't break any water regulations. If you are unsure @ShaunCorbs@ShaunCorbs you could speak to Harvey direct.
    And yes I have listened to you and installed it only to the rest of the house.
    Is a Drinking Water Tap a Legal Requirement? | Harvey
  10. ShaunCorbs
    Yes there is read your water regs book
  11. Matchless.plumb
    So, it means Harvey would give false information and a false statement at their page ? Don't you think they should know if that would break the water regs or not that's definitely their job to know
  12. ShaunCorbs
    It will be listed in there book install to bs6700 etc and make sure it's installed by a qualified person
    Passes the blame on
  13. Matchless.plumb
    For me it's a false statement given by their installer teams
  14. rpm
    rpm Trusted Plumber
    Think you mean their sales team Ron, it is always the same game being played by manufactures "If all else fails blame the installer", I also noted something about not recommended in that link.
    • Like Like x 1
  15. Ric2013
    Ric2013 Plumber
    Water Regs book classes softened water as category 2 and states that cat 2 water 'is considered to present no human health hazard'. But common sense would dictate that a drinking tap has to be suitable for EVERYONE, not have excluded people lists. Also, page 10.5 makes it clear that drinking water from a softened source could become unwholesome if not properly maintained, and that proper maintenance may not always take place in domestic environment, so a separate feed is recommended.
    • Like Like x 1
    • Agree Agree x 1
Loading...
Similar Threads - Protect power shower Forum Date
35cdi hw only when ch on. Since power cut. Plumbers Arms May 9, 2018
what percentage of fitters own a powerflush machine Gas Safe Registered Plumbers Only Apr 2, 2018
