Discuss Pressure relief valve/ overflow pipe hot water discharge in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I’m hoping for a little help with the below problem.
What I believe to be the pressure relief valve exiting out the side of my flat has a constant flow of hot water discharging from it. It is located right next to my boiler although it is boxed in. I am having trouble diagnosing (very basic plumbing knowledge!) so any help as to why this has started occurring would be great. Thank you.
Craig
Or the filling loop has been left open
Always ensure the filling loop is disconnected after use as per regulations. It should only be used as a temporary connection to fill up or top up the system. Left on it could let by and keep increasing the pressure to the point that the PRV is activated. And also could contaminate the fresh water drinking supply. Unfortunately we see it on a daily basis where the filling loop is left permanently attached but this is not correct. Put 1/2" female caps on the two ends of the valves once the loop has been taken off in case of let by to stop any drips or leaks.
Reply to Pressure relief valve/ overflow pipe hot water discharge in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
