Discuss Power flushing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
world9563
Just a quick one guys but i think im right in saying that you have to be corgi to do powerflushing just that i no some one whom as just bought a machine off ebay and going to start and he as no plumbing quals etc or nothing. Your advice greatly appreciated so i can then go advise them
you don't need to be corgi to do power flushing because it has nothing to do with the gas side of the CH, If its an old system that your power flushing it can cause leaks so he will need to be prepared to repair the CH system if there are any leaks
oh i do like a laugh
as uug197h said you can do powerflushing if you can do the rest that gos with it.
understanding a central heating helps as 9/10 systems that powerflushing also need extra work as well, as in radiator valves changed, understanding where the blockages occur, how to powerflush a heat exchanger, use the right chemicals for the right job as many can distroy a combi boiler.
people use powerflushing as a way to print money in many cases a good chemical in the system for a while and then flushed will sort the problem.
you won't earn a living out of just powerflushing.
Thankyou both for your replies i had already told him that only powerflushing will not make him a living but he already bought machine off ebay. i have copied replies and showed him them i just think he is being daft and i was realy hoping that i could bought it off him half price or something if had to be corgi to do it. thankyou again for advise
Reply to Power flushing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have recently bought a house which is 17 years old. There was a small leak from one of the radiators So I took the pipe off and drained the radiator and the water was black/brown. I took the radiator off and flushed it out with a hose pipe out the garden but it's got me thinking and I...
Hi i bought the house that Jack built and ohh has the heating been left to spoil. Prior to moving in 2 new firebird boilers were fitted, silver utility 35. The system is in dire need of a power flush and I intend on using FX2 to do the job. Can anyone advise if FX2 is ok with this boiler model ?
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs covering at leave twice the floor area As per diagram has free flow Up or Down, no way to balance. Works pretty well but last few Rads (in kitchen) are...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer called the next day and diagnosed a faulty pressure switch. This was changed and everything seemed ok. However then the boiler began to lose pressure...
