Discuss Positioning of boiler Flue on external wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I’ve bought a new build that’s just had kitchen installed (due for completion in 8 weeks) I went to see house this week and saw my house differs to others on site. (They are semi-detached and mirror each other, with flue on the side) my semi detached is different, they put my flue on front of house and the attached house, their flue to the side. When I questioned it, the site manager said it was ‘a minor adjustment they made and it was tough’. It sounds petty but their reply really annoyed me.
I’m wondering what the regulations are with regards to width from other house and whether there is something I can do to have it altered, as I know it’s going to annoy the crap out of me.
why o why have they put an brown cover plate on
I know I think that’s why it’s stuck out more. The other comment is the flue had to go on front due to gap on side, not sure why they didn’t put the adjoining house flue to front too so it matched. I think they messed up with gap to side. It’s really going to annoy me as it’s different to the other houses.!
I wonder if there’s anything I can do, if the gap is too small. Cream Flue? Bury the site manager.! (Joke) doubt they have mirror next door to match mine now.
depending on boiler they might do a white flue eg
if theres a flue to the left of you in the gap that ones not right either
As Town has quoted the flue position is correct it could not exit the other wall as it is to close to your neighbours boundry and property what make of boilers are being fitted ?. Cheers kop
Huh? That gap between the houses looks more than 600mm so it depends where the boundary line is, probably something daft like run out of correctly sized kitchen cabinets so had to stick the boiler somewhere else. Not much you can do now 'cept make it look less conspicuous as above.
If it annoys you so much just paint the cover the colour of the house .
Yes that has already been discussed thanks.
As it’s a build currently under construction they should have really done the positioning of the flu correct, matching all the other houses. Especially as this is the last phase of houses being built of a big development. Thank you for your understanding.
I think the exposed white service pipe going up to the utility box is naff but the house looks nice and neat. When it’s all done and weathered a bit most things will melt into background. Thro a bit of old milk on the wall to get fast genuine mould ...that’s the funny bit
That’s when they normally “change” things.
Reply to Positioning of boiler Flue on external wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We are considering buying a house which currently has a 20 year old Ideal Icos boiler, so we're factoring in replacing the boiler soon. Current boiler is on an external kitchen wall with the flue going straight out. However, it's positioned in between a door and the kitchen window, quite close...
E
Hi all, Apologies if this has been covered elsewhere but I can't find an answer to my questions. I have a back boiler and gas fire which h has been serviced regularly over the years by different engineers with no issues. Last time , the guy wanted to condem it due to not being compliant with...
HI, Closing the internal house Stopcock located under the sink eventually stops water flowing from the kitchen tap or washing machine hose when these are left open. However, if the tap/ hose is closed, with the stopcock still isolated and left for several minutes then there is another stream...
1K
T
Morning, Im in a top floor tenement flat with access to the attic space. I have a combi boiler with flue that emits vertically up through the roof. My kitchen is situated internally with no easy access to an external wall. Could I fit a kitchen extractor that ducts vertically then right angles...
Hello. I'm hoping to get some advice. I moved into a new build house a few years ago. A Firebird Silverpac external oil boiler (kabin pak type) was installed which is situated on top of the detached garage base - I've now decided to build the garage meaning the boiler will be now be located...
1K
