Discuss Plumbers mait/putty in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dave1
Whatever happened to Black Swan plumbers mait, nowhere seems to stock it anymore. They all supply the evo stick one which is horrible to use.
Not seen it for a good while.....their solvent cement was lethal in confined spaces IMHO plenty of fumes lol regards Turnpin:dizzy2:
Reply to Plumbers mait/putty in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I have a problem. I have replaced the pan connector from the toilet to the waste pipe however it’s still leaking. I’ve added plumbers mait which still didn’t fix the leak. Is it possible to replace JUST the black seal in the 3rd photo attached with purple arrow? I can’t replace the...
2K
Hiya fellow gas engineer. Need some help on this boiler fault. Went out to this E133 Error on a Potterton Titanium 24 (GC: 47-393-39) I checked the inlet standing pressure which was at 25mb. Boiler attempts to fire and the pressure drops by 1mb but the gas valve doesn't open. Checked the black...
This sounds like an examination question but it really is a problem two different plumbers have been unable to resolve after spending several hours studying my hot water system. My flat has a vented hot water system supplying hot water to the kitchen and bathroom taps. The pump is a Stuart...
Hi All After having pooling water on my drive, I dug down around to find: Black pipe poly/plastic dug 450mm deep spraying water at mains pressure from small hole/crack The outside of pipe (measured with veneer caliper) at 23.5mm Pipe Runs under drive, along side of property and looks to go...
Evening all. Not sure if this is the most appropriate place to post this in the forum, happy to move if not. I'm looking for a metallic 32mm matt black waste pipe, to match up with a matt back trap. The pipe that comes with the trap is 400mm, which isn't long enough for my installation. I'd...
