Discuss Plumber wanted Slough, Berks area to replace hot and cold isolation stop tap valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
Am looking for a qualified plumber to replace two isolation stop tap valves - one on the cold water pipe and one on the hot water pipe under the kitchen sink leading to the kitchen quarter turn ceramic mixer tap. (Neither of the stop taps are the main stopcock on the cold mains water supply to the house.) The stop tap on the cold water pipe is corroded and is leaking just a little bit and the one on the hot water pipe is also corroded but isn't leaking, but we feel we might as well replace it as well.
The stop taps are in an awkward position under the kitchen sink and we think that the plastic pipe work - u bend etc- might have to be removed to gain easier access to the stop taps. We would obviously need the plastic pipework to be put back afterwards.
The hot water is supplied by a combi boiler system, so we would need someone who could make sure that the hot and cold water is working again okay, that there are no airlocks or anything after the job has been done and to re-pressurize the boiler if necessary.
The job is in Slough, Berkshire.
Please private message me if you are interested in the job.
Biilee
Re: Plumber wanted Slough, Berks area to replace hot and cold isolation stop tap valv
Thank you for placing your works request on forums
Should any member be able to help ,please pm op as requested
Reply to Plumber wanted Slough, Berks area to replace hot and cold isolation stop tap valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in kitchen only Stopcock in kitchen wall panel turns off cold water supply in kitchen only Red gate valve in airing cupboard next to bathroom turns off...
I have a Bristan Manhattan mixer tap in the kitchen. Five years ago, it started to drip. I replaced the valve in the cold water side and the dripping stopped. Recently it began to drip again and I replaced the valve again. But, it still drips sometimes. I’m trying to replace the valve on the...
I had an outside tap fitted by a professional plumber last autumn. During the recent cold weather the feed pipe under the kitchen sink froze and the compression joint where the pipe enters an isolation valve now leaks. The outside tap was covered for the winter by an insulating blanket. I...
Hi everyone, I turned my cold water feed off in the airing cupboard which supplies only cold water to my bathroom but it also turned the water to my toilet off is that a correct set up? Because it didn't used to before the stop valve in airing cupboard only turned off the cold water supply to...
